EU Cookie Policy Pro + Auto Cookie Detection
(26 reviews)
  • Recommended for every webshop to improve the EU Cookie Policy
  • Enable / disable single cookies or cookie groups in the shop
  • Automatic cookie detection
  • Cookie backend administration and grouping of cookies by functional groups
  • Individual styling of the cookie groups in the plugin config
  • Google Consent Mode V2 support as well as GA4 and Google Ads (from plugin version 7.4)
  • Selection of the cookies in the storefront
  • Change between modal window and classic cookie notice
  • Cookies are only allowed after acceptance in the shop
  • Automatic cookie detection per language- or subshop
  • Cookies backend administration
Recommended by the IT-Recht Kanzlei Munich: https://www.it-recht-kanzlei.de/rabatt-mandanten-eucookierichtliniepro-shopware.html
Improves the EU Cookie Policy compliant use of your webshop.
Since Shopware can not prevent cookies also from the version 5.6.3 from external scripts (eg Google Analytics) and thus tracking is also possible without accepting, this plugin is nevertheless urgently needed.
  • Non-functional cookies of the shop domain are only allowed in the shop as soon as the user accepts the cookie hint.
  • The cookie hint allows the user to activate / deactivate single cookies or whole cookie groups individually.
  • Cookies unknown to the plugin will be recognized automatically. These can then be titled by the shop owner and activated for selection in the store. Publicly known cookies (such as Google Analytics, Facebook Pixel, Amazon Pay, Livezilla, Cloudflare, Emarsys and many more) are automatically added to the cookie hint.
  • Cookies are automatically assigned to the recognized language- or subshop and only displayed there in the notice.
  • In the plugin settings you can switch between two layout options (Classic cookie note and modal window).
  • Shop customers can adjust cookie settings after accepting (to set up the feature, see the installation instructions).
  • Buttons "Accept only functional cookies" and "Accept all cookies" can be to the note by plugin configuration if required.
  • New from version 7.4: Google Consent Mode V2 support
Technical functioning
The plugin recognizes all cookies set via HTTP or via Javascript from an internal (e.g., Shopware CSRF token) or externally loaded script (e.g., Google Analytics). All cookies that are not set for the shop domain and set by an external loaded resource (eg iFrame integration) for an external domain (eg www.paypal.com) can not be recognized by the plugin due to the same origin policy (browser security guidline) and can not be prevented. As an example, this concerns payment bindings loaded via iFrames (e.g., Paypal Express Shopware plugin).
Please note
The Plugin manufacturer assumes no liability for the complete DSGVO conformity and no claim to legal certainty can be asserted. In particular, it should be noted that each case is to be considered separately and does not replace individual legal advice.
Documentation for Implementing Google Tag Manager
https://www.acris.at/media/5f/e2/1f/1709126654/SW5_Doku_Cookie-Richtlinie-Pro_Tag-Manager_V51_DE.pdf
Container template for the import into the Google Tag Manager (please unpack ZIP archive)
https://www.acris.at/media/GTM_Container_Vorlage_bitte_entpacken_v4.zip
Performance optimisations: Integration via cache cookie instead of ESI tags (since 5.0.1)
The cookie plugin is originally integrated via ESI tags. However, this can slightly impair performance in some shops.
As of plug-in version 5.0.1, there is an additional option to integrate the cookie hint via a cache cookie. The following configurations must be made for this:
  • Plugin setting "Include cookie banner by" must be set to "Cache-Cookie".
  • Configuration of the Http-Cache Cookies via the config.php file. The following PHP code must be inserted into the config.php file (advanced - please do not make any mistakes here!):
    'httpcache' => [
        'cache_cookies' => [53 => 'acris_cookie_acc',54 => 'allowCookie',55 => 'cookiePreferences']
Contact
You have any questions about the plugin or are you looking for an e-commerce specialist to realize your individual shop projects or requirements? Our qualified and highly motivated e-commerce experts will advise you.
  • Latest update: 30 April 2025
  • Publication date: 11 November 2019
  • Version: 7.4.8
  • Category: Storefront
Reviews (26)
Based on 26 reviews
4.9 Usability
Mehr braucht man nicht
by Markus Michalski
22 May 2024 13:30
Mal davon abgesehen, dass das Plugin genau das macht, was es soll, muss der Support wirklich hervorgehoben werden.
Selten so einen schnellen und zuvorkommenden Support erlebt.
Funktionales Plugin und super schneller Support
by R.S.
14 February 2024 13:22
Das Plugin verwenden wir über mehrere Firmen in verschiedenen Shops und läuft sehr stabil und erfüllt genau unseren Zweck.
Hervorheben muss aber, gerade in der heutigen Zeit, den tollen Support den ACRIS leistet. Herzlichen Dank an dieser Stelle nochmals für den Komponenten und sehr schnellen Support.
Super Plugin mit ausgezeichnetem Support
by Timo H.
4 January 2024 09:54
Das Plugin wird von uns in div. Shops genutzt und leistet sehr gute Dienste.
WENN es mal hakt / es mal Fragen gibt, gibt es einen sehr guten und zügigen Support :-)
Top Plugin mit Super Support
by B J
27 March 2023 12:03
Toller Support, super schnelle Reaktionszeit. Mit Anleitung zum Einrichten des GTM-Trackings für GA4. Vielen Dank
Perfekter Support - Tolles Plugin
by Meier Stefan
22 March 2023 10:52
Wir möchten uns vorab bei Herrn Aumayer für die kompetente Hilfe bedanken. Da bei uns ein weiteres Fremd-Plugin mit beteiligt ist, war die Konfiguration im Tag-Manager kompliziert. Nicht jedoch für das Acris-Support Team.
Danke für das tolle Plugin und die Unterstützung.
Sensationeller Support!
by Selda
1 February 2023 16:43
Wir hatten Probleme beim Einrichten des GTM-Trackings für GA4. Sogar ohne Zugriff auf den GTM konnte Wolfgang den richtigen Hinweis geben, sodass wir das Problem lösen konnten. Sensationell!
Super Support, gute Skalierbarkeit
4.5
by Henning Müller
12 January 2023 10:31
absolut empfehlenswert
4.0 Functionality
4.0 Usability
Top Plugin
by M S
11 January 2023 17:07
Guter Funktionsumfang. Sehr engagierter Support. Prima Plugin!
Toller Support
by MW
28 November 2022 16:32
Toller Support, schnelle Reaktionszeit. Umfrangreiche Funktionen. Werden wir auch in Shopware6 wieder nutzen. Vielen Dank!
Sehr gutes Plugin und super Support
by MZ
13 May 2022 15:26
Das EU Cookie Tool lässt sich umfangreich konfigurieren und auch optimal an den Shop anpassen. Der Support reagiert sehr schnell und ist immer hilfsbereit. Sehr gut, weiter so!
  • Ø-Rating: 4.9
  • Extensions: 156
  • Based in: Austria
