Show partial deliveries in shopping cart and collective delivery
Rating: 4.9
(8 reviews)
  • Rule-based display of partial deliveries in the cart
  • Different delivery times and messages per rule possible
  • New delivery statuses: “backordered” or “in progress”
  • • Rule-based splitting of the cart into partial deliveries
  • • Optional selection between combined and partial delivery in the frontend
  • • Display of partial deliveries in the customer account
  • • Individual shipping costs per partial delivery definable
  • • New delivery statuses: “backordered” and “in progress”
  • • Splitting based on available quantity per item possible
  • • Selection of shipping method per partial delivery in the frontend (if multiple options exist)
  • • Email template included for displaying partial deliveries in order confirmation
  • • Support for TWIG variables in partial delivery information
Purpose
The plugin enables the display and control of partial deliveries in the Shopware cart. It allows a transparent and rule-based division of orders into multiple shipments, improves communication with customers regarding order status, and allows granular control of shipping options and costs.
Possible Use Cases / Scenarios
• Splitting immediately available and backordered products in the cart
• Shipping via different carriers, e.g., parcel service and freight forwarding
• Mapping custom business rules for deliverability and shipping options
• Allowing customers to choose between combined or partial deliveries during checkout
Usage
Once installed under Settings > System > Plugins, the plugin is ready to use. Preconfigured rules are included and can be edited or expanded via Settings > Shop > Rule Builder. Partial delivery rules are managed under Settings > Extensions > Rules for Partial Deliveries. The division of deliveries appears automatically in the checkout and in the order confirmation, provided the included email templates are activated.
Configuration Sections
Products
Rule-based grouping of products based on stock levels, attributes, or other conditions.
Actions
Enable selection between combined and partial delivery in the frontend.
Conditions
Define rules for delivery splitting, shipping cost calculation, and cancellation behavior per status.
Communication
Use the included email template to display partial deliveries in order confirmations. Activation via Business Events or Flow Builder is required.
Limitations / Notes
• The included email template must be activated for correct display of partial deliveries in order emails
• Rule definitions for partial deliveries must be set up logically in the Rule Builder
• If multiple shipping methods are used, the customer must select them in the frontend
• The blacklist for non-cancellable statuses must be maintained manually
• The display of partial deliveries depends on the defined rules and product stock levels
  • Latest update: 31 July 2025
  • Publication date: 28 October 2020
  • Version: 13.0.6
Reviews (8)
Based on 8 reviews
4.8 Usability
4.6 Documentation
Super schneller support der auch meinen kleinen Bug behebte
by Michi
10 September 2024 15:17
New: Probably NR1 Support was Shopware Plugins angeht. Hatte ein Problem mit einem anderen Plugin und Acris geschrieben, sofort geantwortet und innerhalb 2 Tagen wurde das Problem behoben. Danke. LG
Old: Wahnsinn, ich hatte ein Problem mit dem Theme das ich nutze und nichtmal innerhalb eines Tages kam ein Update. Ich brauchte das Plugin dringendst, da wir tagtäglich mehrere Versandwarenkörbe/Mischwarenkörbe verkaufen.
Super vielen Dank!
Update: Julian war asap parat und hat mein Problem super schnell gelöst.
alles was das herz begehrt
by William Rau
25 August 2024 15:31
Schneller und unkomplizierter Support
4.5
by Sascha Seyfert
6 February 2024 13:41
3.0 Usability
One of the most unique extensions in the store
4.5
by Stan
9 November 2023 12:12
This extension makes it possible to offer multiple deliveries, all with their own delivery methods and shipping costs, based on rules. This was exactly what we needed and something Shopware does not offer out of the box.
We had an issue with a certain rule with the shipping price matrix, which Acris released a fix for within hours. Support is great aswell.
3.0 Documentation
Klasse Plugin und hervorragender Support
by Dennis Heinzmann
30 June 2022 10:36
Das Plugin erhöht durch eine transparente Ansicht der verschickten Paketanzahl die User-Experience und senkt zudem die Support-Nachfrage nach Paketen deutlich. Der Support reagiert sehr schnell und ist offen für Anpassungen. Klare Empfehlung!
Exzellenter Support
by Klaus Hagemeister
4 January 2022 13:41
Das Plugin ist genau was wir brauchen und der Support war super.
Tolles Plugin mit hervorragendem Support
by Dennis Heinzmann
19 November 2021 09:48
Das Plugin erfüllt alle Erwartungen und der Support reagiert engagiert auf Änderungswünsche und Rückfragen.
Tolles Plugin & super Support
by Mischa Wolfframm
6 October 2021 14:26
Plugin tut was es soll und Hersteller hilft sehr schnell bei Problemen. Top!
4.0 Documentation
  • Ø-Rating: 4.9
  • Extensions: 156
  • Based in: Austria
