- Fixes a problem with potential out of memory error when using with third party plugins.
- Fixes a bug of Shopware during login where it can be that payment and shipping method error comes if sales_channel_api_context is expired and if the cart is empty.
- Improves compatibility with third-party payment plugins.
- Fixes a problem with plugin activation with third-party payment plugins.
- Added a new custom field "ACRIS Default Payment method" to the customer. This field is now being considered when the payment method is preselected depending on the configured plugin configuration.
- Code optimizations. Removal of no longer needed use statements from classes.
- Fixes possible issues where the shipping or payment method could no longer be changed after a subsequent change of the payment method.
- Change of the description texts of the plugin settings according to the logic change of Shopware with version 6.6.
- Fixes possible problems where the shipping or payment method could no longer be changed.
- Optimization of the check for available shipping and payment methods when the cart is empty or emptied.
- Optimisation when removing payment and shipping method errors when logging in if the shopping cart is empty or if the user was logged in via the admin.
- Fixes a bug of Shopware during login where it can be that payment and shipping method error comes if sales_channel_api_context is expired.
- Optimisation if the default payment method set for the customer is to be preferred (set in the plugin configuration).
- Optimizes checking for method preselection in the checkout process.
- Pipeline has been updated
Compatibility with Shopware 6.6. established
Adds validation on changing payment method.
Adds new plugin configuration for resetting the shipping and payment methods used after completing the order.
Improves plugin compatibility.
Optimizes the loading of the default selected checkout methods.
Improved compatibility with Shopware versions >= 6.5.0.0.
Compatibility established for SW 6.5
Optimises the option that the selected payment method and not the customer's payment method is selected at login.
Optimizes loading of the columns in administration.
Compatibility with Shopware 6.4.10.0.
Compatibility with Shopware 6.4.9.0.
Optimizes filtering of the active payment methods.
Optimizes updating of the custom fields.
Optimizes loading of the payment methods in cart.
Optimizes the payment and shipping methods preselection at the order edit page in Storefront.
Fixes an issue with the display of additional fields for payment and shipping methods in conjunction with other plugins.
Fixes problem on preselection of the payment and shipping method at account order edit page.
- From now on, the changed shipping and payment method and the associated shipping costs will be calculated and displayed correctly in the offcanvas shopping cart.
- On the shopping cart and confirm page, there is no longer a redirect after the automatic change of the shipping or payment method and the change is made immediately.
Improved compatibility with Shopware 6.4*.
Fixes a possible error when the request route cannot be found.
