Vouchers (discounts) - residual value management
With this plugin you can redeem (coupons (discounts) even below the actual value. The not redeemed residual value can be redeemed with a further purchase.
Compatible with:
6.3.0.0 - 6.6.10.4
Includes:
Short description
For vouchers (absolute discounts) a residual value management including order history is available. Functional scope of the residual value managementFor discounts of the type "Absolute" a residual value is calculated when redeeming individual coupon codes. This residual value can be redeemed for further orders.
The residual value can be viewed in the administration. In addition, the residual value can also be tracked in the order history.
Short instructions
After installing the plugin, the function is immediately available:
- Create a coupon:
Marketing: Discounts & Coupons:
Create a promotion: Name, Active, Sales channels -> SAVE
Use action codes (activate) -> Use individual action codes (activate)
Manage individual action codes -> Create coupon codes according to Shopware standard z. B. ACRIS-%s%s%d -> Save and generate codes
Target group: Define as needed
Discounts: Add discounts and set ART to absolute and define the coupon (discount). - Residual value management
The residual value management was completely integrated into Shopware - that means, where normally it is visible who has redeemed which coupon code.
Marketing -> Discounts & vouchers -> "edit" the corresponding voucher -> manage individual promotion codes -> click on "order history" for the corresponding voucher code and the window opens where you can see when the voucher was redeemed with which order.
Redeem discounts for shopping cart and shipping costs
In Shopware Standard it is only possible to redeem discounts for the shopping basket or the shipping costs. With the plugin it is possible to redeem discounts for the entire shopping cart and the shipping costs. After activating the plugin, a new selection option is available.
Known limitations
- With the activation of the plugin, all discounts (vouchers) of the type "Absolute" are equipped with the residual value feature. <In the future, it will be possible to set this feature on individual discounts (vouchers).
- Available: English, German
- Latest update: 8 May 2025
- Publication date: 28 October 2020
- Version: 5.0.0
- Category: Promotions & Voucher
Reviews (2)
Restwertverwaltung klappt, Rabatt auf Warenkorb & Versandkosten anwendbar und 1A Support
by Kaja Schäferhoff | limmaland.com
17 October 2023 09:36
Functionality
Usability
Documentation
Einwandfreie Funktionalität und lobenswerte Support
by Hans Jung
19 January 2022 10:50
Genau die App die wir für unsere Aktionen gesucht haben!
Nach einspielen eines Backups gab es ein kleines Problem, welches
aber umgehend gelöst wurde. Top Erweiterung und Top Support
Functionality
Usability
Documentation
Bronze Partner -
- Ø-Rating: 4.9
- Partner since: 2015
- Extensions: 156
- Based in: Austria
- Speaks: German, English
- Response time: Very quickly
