Flexible Canonical Tags for Products
  • Instead of using the canonical tag of the own product, the canonical tag of another product can be assigned
  • Targeted indexing of products instead of unnecessary, similar or identical products
  • Multiple modification is supported as well as Shopware API
  • Instead of using the canonical tag of your own product, it is possible to assign the canonical tag of another product to the product.
  • Assign individually directly at the products or via multiple processing or via API.
Purpose of the APP
This function allows you to assign the canonical tag of any other product to a product instead of its own "product canonical tag".
This is particularly useful if search engines are to index only one product instead of several products, for example in the case of variant products.
The assignment of the desired canonical tag is done directly via an additional field on the respective product. It can be done either via a multiple change or via the API.
Advantages of the APP
  1. Flexibility with Canonical Tags
    Instead of using only the own "product canonical tag", the canonical tag of any other product can be assigned to a product. This allows individual control of the canonical URLs.
  2. Targeted indexing
    If you have variant products and want search engines to index only a specific product, you can set the canonical tag accordingly. This way you avoid unnecessary indexing of similar or identical products.
  3. Simple assignment
    The assignment of the desired Canonical Tag is done directly on the product via an additional field. This makes it easy and convenient to make the desired settings.
  4. Efficient implementation
    The function can be performed either via a multiple change, which is especially convenient if you want to edit multiple products at the same time. Alternatively, you can also use the API to make the assignment programmatically.
With these highlights, you can improve the search engine optimization (SEO) of your products, target indexation, and provide a better user experience.
Known limitations
  • The app does not make a check if the specified "other" product number is active or present.
  • Only one product number can be specified per product at a time.
  • Latest update: 12 May 2025
  • Publication date: 19 May 2023
  • Version: 2.0.0
  • Category: SEO Optimization
  • Ø-Rating: 4.9
  • Extensions: 156
  • Based in: Austria
