Search Pro with Elasticsearch search option or OpenSearch
(16 reviews)
  • Shopping experiences creation for search results and assignment to corresponding search terms
  • Prioritize products (in categories, in the search preview or in the search result)
  • Restrict search results
  • Synonyms (example: search entry "Laptop" is the same as "Notebook")
  • Influence search results through prioritization and restriction in: the search preview, the search result and also the category listing
  • New Layout for Suggest-Search available
  • Shopping experiences can be created for search results and assigned to corresponding search terms
  • Search terms and search results are automatically tracked. You can use the results for detailed evaluations
  • Use synonyms
  • Influences the search preview, the search result and also the category listing
  • Search preview in the admin interface per sales channel with ranking value
  • "AND" instead of "OR" linking of multiple search terms (with and without ElasticSearch from plugin version 3.0.0)
  • Manufacturer and Categories also include in Search
  • Exact match with Product Numbers, EAN, Manufacturer number (Plugin Configuration)
  • Shopping Experience worlds can now be created for search results and assigned to corresponding search terms.
  • Custom landing pages can now be configured as search results pages for specified search terms.
Configuration of the plugin
To configure the plugin: Settings -> Plugins -> Search Pro
With the installation of the plugin a new "Sorting" will be created in the product listing -> "Best Results".
Only with this sorting the rules in the frontend will be applied.
The plugin works both with and without Elasticsearch or OpenSearch connection and improves the search in both cases in addition to the added functions (see below).
Features of the plugin
Application example: The shop admin wants to check his configurations without having to switch to the frontend.
Below the possible configuration of the plugin, we have integrated a search preview.
  • First please select the right sales channel, then you can enter the search terms.
  • The search preview considers all set rules and additionally outputs a "ranking" value.
  • This means that if you change the FACTOR for any of the rules, you can immediately see the effects on the search         result.
Searchable content (from plugin version 10.0.0)
It is possible to make additional content searchable.
An individual search ranking can be defined for the additional content depending on the fields included.
Not only standard Shopware content (manufacturers, categories, landing pages) can be made searchable. Content from any other plugins can also be searched. The prerequisite for this is that the other plugin stores an SEO template for the content to be searched under Settings > SEO.
Note: Before plugin version 10.0.0, manufacturers, categories and landing pages were already searchable. The settings for this were still in the general plugin settings and were less extensive.
Prioritize products
Application example: A user is supposed to be shown certain products in the listing when entering a search or in categories
  • Please create "Dynamic product group" first
    To use this feature properly, you need to create a dynamic product group to define the selection of products to be prioritized.
    This is done in the Shopware Standard under CATALOGS -> DYNAMIC PRODUCT GROUPS
    Then configure prioritize product
    Settings -> Plugins -> Search Pro -> prioritize products -> "add".
  • Internal designation    is displayed in the overview, serves to clearly describe the         product prioritization rule
  • Active     each rule can be set active / inactive
  • apply to
        the rule can be applied in several areas:
Search and search     preview:  The rule prioritizes the products defined in the "dynamic product group" in the search preview and in the search result
    Categories: The rule prioritizes the product listing in a category, the products defined with "dynamic product group". This is independent of a search.
Search, search preview and category: The rule is applied in all 3 cases.
  • (Optional) Search terms:
        If search terms are specified, the prioritization of products is only active if one of the search terms or the synonyms specified for it are entered in the search. This has no effect on the product listing.
  • factor:
        The factor can be used to set a weighting - this has an effect on the prioritization. The calculated ranking value is displayed in the search preview.
        Please adjust the values in smaller steps (50-100), otherwise the rankings may be shifted strongly.
  •  Dynamic product groups:
        Here the product groups defined at the beginning are assigned - this can be one or more.
        An OR link has been implemented: All products in the dynamic product group 1 or 2 are prioritized.
Restrict product search result
Application example: A user should only find products with stock level > 0.
  • First please create "Dynamic product group
    All products from the dynamic product group are then used / displayed with the corresponding search restriction rule.
  • Then configure Prioritize product
    Settings -> Plugins -> Search Pro -> Restrict product search results -> "add".
    If the user searches in the frontend for one of the specified search terms or their synonyms, the search results are restricted to those in the specified dynamic product group. If no search term is entered, the rule is not limited to one (or more) search terms, but is applied to each search term.
    The product groups defined at the beginning are assigned here - these can be one or more.
    An OR     link has been implemented: The search result is restricted to the products that are in the dynamic product group 1 or 2.
    All products from the dynamic product group are then used / displayed in the corresponding search restriction rule.
  • Restriction type
    - Replace: Search results of dynamic product group are output independently of the         search word
    - Limit: Search results are output based on search term and additionally limited by dynamic         product group
Attention:
    Due to several errors in the Shopware Standard for the dynamic product groups, errors may occur in the frontend.
    Please change the dynamic product group rule to numeric queries if possible.
    Example: If you create a dynamic product group on NAME contains XYZ, an error will be visible in the frontend.
    If you create a rule with LAGERSTAND > 0, it will work correctly.
Search words
SEARCHWORDS in the current version only serve as an overview if they are used in other functions of our plugin.
In future versions it will be possible to display statistics here.
Synonym Rules
Application example: A user entering "Laptop" should also find search results with "Notebook" (and vice versa)
The synonym rules are only applied to the search.
  • Internal name    is displayed in the overview, serves to clearly describe the product         prioritization rule
  • Search terms   Specify which search terms should behave like synonyms. A 1:1 connection is made         here, which means that all entered search terms are always found "vice versa".
Exact search (from Plugin version 4.4.0)
Allows you to specify fields in the plug-in settings     where only the products found are output for exact matches. In the standard version this concerns the fields:
  • Product number
  • Manufacturer number
  • EAN
Since plugin version 8.7.0 it is also possible to include any additional fields in the exact search. This can be configured in the plugin settings.
Shopping experiences in search preview and search results (from Plugin     version 6.9.0)
Replace search results with shopping experiences / completely redesign (from plugin version 8.6.5)
Search     results pages can be completely customised and influenced by shopping experiences.
To do this, you must first     create a new entry under "Settings > Extensions > Search Pro > Shopping experiences in search results" and     select the option "Show shopping experience" > "Replace the search results page with the shopping     experience".
In the shopping experience there is an "ACRIS search" block in which all the required elements are     available.
Redirect - if a term is searched for, then redirection to a specific page (from plugin version 6.9.0)
Under     "Settings > Extensions > Search Pro > Custom search results pages", redirects can be configured depending     on the search term, which come into effect when certain search terms are searched for.
Since plugin version     8.4.0, it is also possible for a redirect to take place if no search results are found. This means that customised     shopping experiences can be used if no search results are found.
Popular search terms (from plugin version 6.10.0)
Under "Settings > Extensions > Search Pro >     Popular search terms", the most frequently searched search terms can be viewed and read out. This can be used to     optimise the search specifically for the shop and customers.
If you are missing any other features, please write us a support request and we will check a possible implementation.
  • Latest update: 21 May 2025
  • Publication date: 20 May 2020
  • Version: 11.0.4
  • Category: Storefront
Reviews (16)
Based on 16 reviews
4.9 Functionality
Tolle Suche, toller Support!
by Arne
19 May 2025 09:07
Eine Suche, die genau das macht, was man von ihr erwartet. Wir nutzen das Plugin in Verbindung mit OpenSearch, was einwandfrei funktioniert. Aber auch ohne OpenSearch sind die Suchergebnisse sehr gut.
Ein kleines Problem wurde umgehend behoben. Erstklassiger Support.
Bug umgehend behoben
by Philipp von Wedel
5 August 2024 11:59
Top Erweiterung.
Wir hatten ein Problem mit einer anderen Erweiterung, die zu einem Bug im Checkout geführt hat.
ACRIS hat sich sofort um die Behebung gekümmert.
Kann ich nur weiterempfehlen. ?
Sehr gute Suche und erstklassiger Support
by Daniel K.
23 November 2023 07:36
Nach einem Update des Shopware Commercial Plugins gab es bei uns Probleme mit der Suche Pro. Die Suche funktionierte nicht mehr richtig mit Elasticsearch.
Der Support hat sich schnell meiner Anfrage angenommen und das Problem gefunden. Mit Updates des Plugins wurden die Fehler behoben und die Suche Liefert wieder erfolgreich schnelle Ergebnisse.
Wir sind sehr zufrieden mit der Leistung des Supports. Die Suche funktioniert jetzt wieder wie gewünscht.
Super Plugin für die Suche mit sehr gutem Support
by Tom R.
11 August 2023 08:05
Sehr gutes Plugin für die Suche mit allen wichtigen Funktionen, damit der Kunde auch wirklich das findet, was er sucht, und mit den individuellen Einstellungen für den Shopbetreiber findet der Kunde dann auch das, was er finden soll. Wir nutzen zudem auch die Sortierung in den Kategorien über den Score. Der Support ist wirklich immer sehr schnell und vor allem absolut kompetent. So macht Shopware Spaß! Danke Acris!
Super Suche
by Gregor Stockschlaeder
12 June 2023 10:22
Wir waren an der Suche von Shopware fast verzweifelt und schon in der Planung für die Suche mit einem Elastiksearch-Server.
Dieses Plugin hat uns davor bewahrt, mit Kanonen auf Spatzen zu schießen ...
Eine Suche, die macht was Sie soll: sie findet und priorisiert richtig.
Toll auch das Erlebniswelten, Kategorien und Hersteller mit enthalten sind. Die Such-Ergebnisse werden übersichtlich präsentiert (im Suchfenster und in der Gesamtsicht).
Kleiner Tipp: wer soviele Einstellmöglichkeiten bietet, sollte etwas Dokumentation schreiben, das entlastet den Support, der aber sehr schnell reagiert.
Ein feines Stück Software - so elegant programmiert, findet man auch mit SQL und PHP!
Endlich funktioniert unsere Suche wie wir es uns gewünscht haben!
by Philipp
21 April 2023 09:53
Dieses Plugin ist der Hammer! Wir hatte immer das Problem mit der Suche, wenn man Fisch sucht das Fleischprodukte erschienen sind. Wir sind fast verzweifelt. Dank des super Supports, der uns das Plugin richtig eingestellt hat funktioniert es endlich so wie gewünscht :)
Klasse Plug-in und toller Support
by Stefan
20 March 2023 10:35
Die Funktionen des Plug-ins und die durch das Plug-in erzielten Suchergebnisse überzeugen uns sehr. Mit dem Plug-in bringt die Suche im Shop wieder Spaß. Der Support ist sehr gut und hat uns bei Problemen innerhalb kürzester Zeit geholfen. Sehr zu empfehlen.
Super
by Christian Sperber
28 February 2023 14:11
Eine echte Bereicherung für (fast) jeden Shop.
Schön wäre es weitere Felder für genaue Suchtreffer wählen zu können.
Sofern es mal ein Problem gibt ist der Support wirklich auf zack.
Tolles Plugin & exzellenter Support
by Willi Steffler
9 February 2023 13:12
Wir benutzen das Plugin im Webshop eines Kunden mit über 50.000 Artikeln.
Das Plugin macht genau was es soll:
Die Suche ist schnell, liefert sehr gute Suchergebnisse und bietet umfangreiche Konfigurationsmöglichkeiten.
Darüber hinaus ist der hervorragende Support von Acris hervorzuheben.
Wir haben in zwei Fällen Kontakt aufgenommen. Beide Male wurde innerhalb eines Tages reagiert, unsere Anliegen vollständig erfüllt und am Folgetag ein entsprechendes Plugin-Update veröffentlicht.
Besser geht's nicht!
Perfekt in Kombination mit Elasticsearch und sehr guter Support
by HNI Marketing @ Saueracker
23 November 2022 12:13
Wir hatten massive Probleme mit der Suchperfomance in unserem Shop. Bei über 25.000 Artikel auch kein Wunder, wenn man die Shopware eigene Suche nutzt. Dann sind wir auf dieses Plugin gestoßen. Wir haben den Pluginhersteller Support kontaktiert, da wir mit Elasticsearch und den Settings kein inhouse Knowhow aufweisen können. Die Entwickler der Acris E-Commerce GmbH waren extrem ambitioniert und konnten schließlich das Problem lösen. Das Plugin entfaltet seine ganze Leistung, wenn dies in Kombination mit Elasticsearch verwendet wird. Hervorzuheben ist nicht nur das tolle Plugin, welches viele Einstellmöglichkeiten bietet, sondern vor allem der hervorragende Support. Hier nochmal herzlichen Dank für die tolle Unterstützung,
Wir können die Acris E-Commerce GmbH wärmstens empfehlen.
  • Ø-Rating: 4.9
  • Extensions: 156
  • Based in: Austria
