CMS Erlebniswelten Pro - CMS / Erlebniswelten Blöcke, Elemente, Grid, Formular Builder
Rating: 4.9
(9 reviews)
  • 18 flexible placeholders
  • Animatable elements for all Shopping Experiences
  • Fully customizable product detail page
  • Extensive collection of elements
  • Configurable aspect ratio and image crop
  • Form builder
  • • Adds over 70 additional blocks and elements to the Shopware Shopping Experiences
  • • Rule-based control of blocks and sections from plugin version 6.8.1 (5.15.0 for SW < 6.5)
  • • Animation options for CMS elements and product boxes
  • • Responsive behavior with configurable column width, order, and spacing
  • • Form fields with dependencies, prefilled or hidden, including Rule Builder and Flow Builder integration
  • • Support for alternative recipients in forms depending on selected field values
  • • Integration with external apps such as Biloba IT Auto Translation Pro
Purpose
The plugin enhances Shopware 6 Shopping Experiences with a wide range of flexibly usable elements and layout blocks. The goal is to offer creative freedom in designing CMS pages, homepages, and product detail pages – complemented by rule control, animation features, and responsive configuration options.
Possible Use Cases
A homepage is built using multiple banner sliders, teasers, and custom-placed category boxes. The product detail page is structured with individual sections like manufacturer logo, product variants, dimensions, and product reviews. Rules can be used to display seasonal content or show certain forms only for selected customer groups.
Usage
In the Shopware admin panel, go to Content > Shopping Experiences. After installation, new elements will be available. Rule control is configured via the Rule Builder using specific conditions. Column and animation adjustments are made directly in the block settings within the Shopping Experience.
Configuration Sections
  • Shopping Experiences: Select and place new elements and blocks
  • Block Settings: Define column width, spacing, and order; activate animations
  • Plugin Settings: Set global animation settings
  • Rule Builder: Define rules for visibility of forms, blocks, and sections
  • Flow Builder: Set up reactions to rules (e.g., alternative recipients)
Limitations / Notes
Rule-based control is only available from plugin version 6.8.1 (5.15.0 for Shopware < 6.5). Some form functions require Shopware version 6.6.9.0 or higher. External tools like Auto Translation Pro must be installed separately.
Placeholders
After installation, over 70 new elements become available in the Shopping Experiences, grouped into eight functional categories. The placeholder layouts allow completely custom designs using empty grid structures with up to 12 columns. These placeholders can be filled with any Shopware or plugin elements and come in a variety of column ratios, including classic 50/50 splits or asymmetric 25/75 layouts.
Blocks
Predefined layout blocks cover typical marketing, content, and product presentation use cases. These include info boxes, banner sliders, text-image combinations, accordions, counters, countdown elements, and more complex layouts like masonry galleries, fullscreen teasers, or custom form sections. Many blocks can be reused across layouts and offer their own configuration options.
Form Builder
The integrated Form Builder expands CMS functionality with a powerful tool for creating complex forms. In addition to standard input fields, it supports prefilled or hidden fields and conditional visibility based on other field values. The Rule Builder can be used to control specific form content, while the Flow Builder allows configuration of alternative recipient addresses depending on selected form options.
Product Detail Page
A key module focuses on the product detail page, which is broken down into blocks and individual elements. Every area—such as product name, gallery, buy box, price, availability, variants, specifications, and dimensions—can be positioned and styled independently. The standard layout can be completely overridden and replaced with custom CMS elements.
Product Listing
New layout options for product listings allow flexible configuration of how many products are shown per row. Different column ratios can be selected, enabling optimal display across devices.
Additional Features
Entire Shopping Experiences can be embedded as CMS blocks, allowing complex layout structures to be reused anywhere in the shop, such as on product or category pages. This increases layout consistency and reusability.
Exchangeable Elements
A key feature is the modularity of elements. Many of the above-mentioned content types—buttons, images, text boxes, product info, teasers—are available both as standalone blocks and as swappable modules that can be replaced or customized in various layouts. This creates a flexible system that adapts to diverse scenarios.
Column Adjustments & Animations
Finally, the plugin enhances design options for responsive behavior and animations. Within the block settings, column width, order, and spacing can be configured per device (desktop, tablet, mobile) based on a 12-column grid. Animations can be defined globally in the plugin settings or individually per element. These are triggered either on scroll or when the element becomes visible, adding a dynamic touch to the content.
  • Latest update: 31 July 2025
  • Publication date: 19 May 2022
  • Version: 9.5.11
Reviews (9)
Based on 9 reviews
4.8 Documentation
Das Plugin erweitert die Möglichkeiten in den Erlebniswelten erheblich. Der Support reagiert zeitnah und hat unsere Proobleme schnell gelöstt.
4.5
by Sven Hamann
30 July 2025 19:25
Insgesamt ein sehr nützliches Plugin, um die Erlebniswelten von Shopware 6 zu erweitern und attraktiver zu gestalten.
3.0 Documentation
Top Erweiterung! Top Support!
by Tobias Eric Garbe
3 July 2025 14:27
Wir haben schon sehr viele Erweiterungen von ACRIS im Einsatz und jede Erweiterung ist einfach wirklich richtig gut. Änderungs- und/oder Anpassungswünsche werden schnell umgesetzt. Wir sind mit den Erweiterungen von ACRIS rundum zufrieden.
CMS endlich einfach
by Christopher Bauer
14 May 2024 14:20
Ich habe das Shopware Plugin "CMS-Erlebniswelten" von Acris im Einsatz und bin äußerst zufrieden. Das Plugin bietet eine Vielzahl von Gestaltungsmöglichkeiten, die es einfach machen, attraktive und ansprechende Seiten zu erstellen. Besonders hervorzuheben ist die Benutzerfreundlichkeit – die Funktionen sind selbsterklärend und leicht zugänglich.
Was mich besonders beeindruckt hat, ist der überragende Support von Acris. Bei Fragen oder Problemen wurde mir schnell und kompetent geholfen. Der Support ist freundlich, gut erreichbar und hat immer eine Lösung parat.
Insgesamt kann ich das Plugin jedem Shopware-Nutzer empfehlen, der auf der Suche nach flexiblen und einfach zu bedienenden Gestaltungstools ist. Ein großes Lob an das Acris-Team für dieses hervorragende Produkt und den erstklassigen Service!
Blitzschneller Support
by FR
22 December 2023 13:09
Empfehlenswert in allen Belangen.
Must Have für SW6
by Dirk Messmer
15 December 2023 15:36
Super Erweiterung für die Erlebniswelten, tolle Elemente, schneller Support .. kann man nur weiterempfehlen
Toll Tool, sehr gut durchdacht
by Florian Weisser
31 October 2023 10:55
Macht Spass damit Seiten Layouts zu bauen.
Großartig!!! Besonders die Funktion
by Alexander Geller
21 September 2023 10:38
Acris bohrt mit dieser Sammlung an durchdachten Plugin-Elementen die Shopware-Standard Funktionen der Erlebniswelten enorm auf.
Als ich eher beiläufig im Kleingedruckten über den Punkt 5 "ACRIS Zusatfunktionen" gestolpert bin - schlug mein Herz bis zum Hals. Nach dem erfolgreichen Test konnte ich mein Glück kaum fassen und führte einen Freudentanz im Büro auf ;-)
Von dieser Funktion habe ich seit Ewigkeiten geträumt. Diverse Plugin-Entwickler haben auf meine Bitte, eine solche Funktion zu programmieren, abgewunken.
Ein riesengroßes Dankeschön an das Acris-Team: Ihr habt mich mit diesem Plugin sehr glücklich gemacht!! ;-)))
Weitere Acris Plugins stehen bereits auf meiner "MUST HAVE" Liste.
Mein persönlicher Plugin-Favorit
by Martin Wagner
14 August 2023 12:05
Neben vielen großartigen Erweiterungen und Tools, wie Rule und Flow Builder, Rabattaktionen etc. sind die Erlebniswelten für mich das herausragende Tool von Shopware. Mit diesem Plugin (und ein bisschen CSS) lassen sich die Möglichkeiten fast komplett ausreizen und Layout-Ideen relativ schnell und unkompliziert umsetzen.
Jede einzelne Block-Kategorie ist dabei an den Bedürfnissen für Anwender orientiert und so umgesetzt, dass man sich sofort damit zurecht findet.
Neben einer Vielzahl essenzieller Blöcke, wie Gallerie, Slider, Akkordeon und und und, haben mich die Produktdetails und Spaltenblöcke am meisten überzeugt. Damit ist es möglich eine Produktseite von Grund auf den eigenen Bedürfnissen und Kundenwünschen gemäß aufzubauen.
Wir haben einige Plugins von ACRIS im Einsatz, sind mit allen sehr zufrieden, aber dieses Plugin toppt alle. Hinzu kommt der großartige Support, der schnell, äusserst kompetent und sehr kundenorientiert arbeitet.
Hilfreiche Funktionen, sehr guter Support
by Michael Schorn
16 June 2022 15:45
Das Plugin erleichtert die Erstellung der Erlebniswelten erheblich. Bei einem Kompatibilitätsproblem hat der Support sehr schnell, freundlich und erfolgreich geholfen.
  • Ø-Rating: 4.9
  • Extensions: 156
  • Based in: Austria
