CMS Erlebniswelten Pro - CMS / Erlebniswelten Blöcke, Elemente, Grid, Formular Builder
- 18 different placeholders can be individually filled with elements
- Product detail page can be completely customised - the essential functions have been broken down into individual elements for this purpose
- Prefabricated blocks and elements that can be used universally in the shopping experiences
- Many of the elements are configurable and can therefore be used in a variety of ways
- Animations globally or individually for experience world elements
- Extends the Shopware shopping experiences with numerous blocks and elements
- From plugin version 6.8.1 (5.15.0 for Shopware < 6.5), blocks and sections can be controlled via rules
Over 70 useful CMS extensions for the Shopware experience:
1. ACRIS Columns Placeholder (empty layout (grid) blocks (here you can use all Shopware elements).
- 1 column
2 columns
2 columns (40% / 60%)
2 columns (60% / 40%)
2 columns (25% / 75%)
2 columns (75% / 25%)
2 columns with spacing (33% / 42%)
2 columns with spacing (42% / 33%)
3 columns
3 columns (50% / 25% / 25%)
3 columns (25% / 50% / 25%)
3 columns (25% / 25% / 50%)
4 columns
5 columns
6 columns
8 columns
10 columns
12 columns
2. ACRIS blocks
- Note (Alert)
Banner Slider
Text Box / 5 Categories Box Slider
HTML Code
Headline (Headline)
Headline and image (right)
Headline and image (left)
Headline and image right (rounded with column offset)
Headline and image left (rounded with columns offset)
Image with Button Box
Masonry Image Gallery
Image Gallery Slider
Four Columns, Link Box
Newsletter (Subscription Box)
2 columns, Teaser Box
Teaser full screen
Teaser side by side
Recommendation
Image full width
Image medium centered
Image small centered
HTML video upload
Formular Builder
Tabs
Button
Accordion
- Counter
- Countdown
3. ACRIS form builder
Powerful form builder with many different field types including prefill functionality and hidden form fields.
Dependencies between fields in the form(from plugin version 8.4.0 for SW >= 6.6.9.0)
Input fields within a form can be hidden or concealed depending on the value of other fields.
Several restrictions can also be specified for each field. These are interpreted as an "OR" link.
Alternative recipients depending on the selected option in the form(from plugin version 7.7.0 for SW >= 6.6, 6.27.0 for SW >= 6.5)
This can be configured and used with maximum flexibility:
-> Via the Shopware Rule Builder
-> and with the Shopware Flow Builder.
Configuration instructions:
-> 2 new conditions are now available in the Rule Builder:
** ‘ACRIS Form Builder Field Value’
** ‘ACRIS form builder form with internal ID’
-> This can be used to create a rule: If form X and value Y selected.
-> This rule can be inserted in the Flow Builder and if this rule is true, an alternative recipient address can be entered there
4. ACRIS product detail (the product detail page was split into blocks and individual elements)
- Product image - gallery (fixed) and buybox (25% 75%)
Product image - gallery large and buybox 75% 25%)
Product name
Manufacturer Logo
Price & Availability
Quantity & Shopping Cart Button
Product number
Manufacturer number
EAN Code
Height
Width
Length
Weight
Product features
Product variants
Product description and evaluation Extensions
5. ACRIS product listing
- Product listing (adjustable how many products should be displayed in a row, depending on the display format)
- Four columns, product boxes
6. ACRIS additional functions
- Experience world (A (selectable) experience world is inserted as a block, this can be used e.g. on the product detail page or on the product overview)
7. (exchange) elements
(these can be used with many blocks)- Note (Alert)
Banner Slider
Button Box
HTML Code
Feature Box
- Headline
Image Gallery
- Link Box
- Teaser box
- Teaser full screen
Teaser side by side
Recommendation
Placeholder
Newsletter
HTML video upload
Category box with image
Text Box
Product name
Manufacturer Logo
Product number
Manufacturer number
- EAN-Code
- Product features
Product listing
Product variants
Product description and reviews Extension
World of experience
Tabs
Button
Accordion
- Counter
- Countdown
8. column customization for responsive design
For all ACRIS elements that are supplied in this plugin, there is the possibility to define the column width, column order and the define column spacing for different output devices.
These settings can be found under the block settings of the respective element. Here you can set the column width, column order and column spacing for various devices (tablet, phone, desktop) differently on the basis of a
a grid with 12 columns. An example: for the desktop display, the first column should take up 25% and the second 75% of the screen and on the tablet both columns should be 50%.
Animations (on scroll or in the visible area)
-> Animations can be configured globally for Shopping Experiences elements and product boxes via plugin settings
-> Animations can be customised individually for each experience world element
Depending on the settings, the animations only work when scrolling or can also be executed in the visible area.
Plugin extension:
From plugin version 6.8.1 (5.15.0 for Shopware < 6.5), blocks and sections can be controlled via rules. This means that page content can be displayed individually for customers or time periods.
- 1 column
2 columns
3 columns
4 columns
5 columns
6 columns
8 columns
10 columns
12 columns
2. ACRIS blocks
- Note (Alert)
Banner Slider
HTML Code
Headline (Headline)
Teaser full screen
Teaser side by side
Recommendation
Image full width
HTML video upload
Formular Builder
Tabs
Button
Accordion
- Counter
- Countdown
Product name
Manufacturer Logo
Product number
Manufacturer number
EAN Code
Height
Width
Length
Weight
Product features
Product variants
Banner Slider
Button Box
HTML Code
Feature Box
- Headline
Image Gallery
- Link Box
- Teaser box
Teaser side by side
Recommendation
Placeholder
Newsletter
HTML video upload
Text Box
Product name
Manufacturer Logo
Product number
Manufacturer number
- EAN-Code
- Product features
Product listing
Product variants
World of experience
Tabs
Button
Accordion
- Counter
- Countdown
Plugin extension:
- Available: English, German
- Latest update: 25 June 2025
- Publication date: 19 May 2022
- Version: 9.5.1
- Category: Shopping Experiences
Reviews (7)
CMS endlich einfach
Was mich besonders beeindruckt hat, ist der überragende Support von Acris. Bei Fragen oder Problemen wurde mir schnell und kompetent geholfen. Der Support ist freundlich, gut erreichbar und hat immer eine Lösung parat.
Insgesamt kann ich das Plugin jedem Shopware-Nutzer empfehlen, der auf der Suche nach flexiblen und einfach zu bedienenden Gestaltungstools ist. Ein großes Lob an das Acris-Team für dieses hervorragende Produkt und den erstklassigen Service!
Blitzschneller Support
Must Have für SW6
Toll Tool, sehr gut durchdacht
Großartig!!! Besonders die Funktion
Als ich eher beiläufig im Kleingedruckten über den Punkt 5 "ACRIS Zusatfunktionen" gestolpert bin - schlug mein Herz bis zum Hals. Nach dem erfolgreichen Test konnte ich mein Glück kaum fassen und führte einen Freudentanz im Büro auf ;-)
Von dieser Funktion habe ich seit Ewigkeiten geträumt. Diverse Plugin-Entwickler haben auf meine Bitte, eine solche Funktion zu programmieren, abgewunken.
Ein riesengroßes Dankeschön an das Acris-Team: Ihr habt mich mit diesem Plugin sehr glücklich gemacht!! ;-)))
Weitere Acris Plugins stehen bereits auf meiner "MUST HAVE" Liste.
Mein persönlicher Plugin-Favorit
Jede einzelne Block-Kategorie ist dabei an den Bedürfnissen für Anwender orientiert und so umgesetzt, dass man sich sofort damit zurecht findet.
Neben einer Vielzahl essenzieller Blöcke, wie Gallerie, Slider, Akkordeon und und und, haben mich die Produktdetails und Spaltenblöcke am meisten überzeugt. Damit ist es möglich eine Produktseite von Grund auf den eigenen Bedürfnissen und Kundenwünschen gemäß aufzubauen.
Wir haben einige Plugins von ACRIS im Einsatz, sind mit allen sehr zufrieden, aber dieses Plugin toppt alle. Hinzu kommt der großartige Support, der schnell, äusserst kompetent und sehr kundenorientiert arbeitet.
Hilfreiche Funktionen, sehr guter Support
Bronze Partner -
Ø-Rating:
4.9
- Partner since: 2015
- Extensions: 156
- Based in: Austria
- Speaks: German, English
- Response time: Very quickly
The plugin is installed as usual in Shopware.
Afterwards, new blocks and elements are available in the worlds of experience.
9.5.1
- Fixes "unable to load template" error in storefront.
7.27.1
- Fixes possible mail sending issue when using info text in form builder.
8.12.0
- Added info text for display field type to the form builder
- Added spacing bottom settings for form builder fields.
7.27.0
9.4.4
- Improved accessibility of the newsletter element.
8.11.5
- Improved compatibility with the Shopware ACCESSIBILITY_TWEAKS flag.
7.26.4
9.4.3
- Fixes critical php error in Storefront.
8.11.4
9.4.2
- Fixed data assignment not working properly for accordion element.
8.11.3
7.26.3
8.11.2
- Fixes syntax error for the ACRIS image element.
9.4.1
- The mobile view and accessibility of the Link Box have been optimized.
7.26.2
8.11.1
9.4.0
- Added possibility to use a video for Teaser full screen element.
7.26.1
- Fixed an incorrect output in the form builder element.
8.11.0
- Es wurde die Möglichkeit hinzugefügt, ein Video für Teaser -Vollbild -Elemente zu verwenden.
7.26.0
9.3.0
- Added new settings for the headline element and for the link box element.
- New image and accordion element settings.
8.10.0
9.2.0
8.9.0
7.25.1
- Link box element display improved.
7.25.0
9.1.0
- Block configurations for vertical alignment have been expanded.
- Responsive view design has been adjusted.
7.24.0
9.0.3
- Fixes wrong accordion element styling when using multiple elements in one page.
8.7.3
7.23.4
- Fixiert das Styling des falschen Akkordeonelements, wenn Sie mehrere Elemente auf einer Seite verwenden.
9.0.2
- Banner slider height control optimization on different viewports.
8.7.2
9.0.1
- Fixes element that load data from the header.
9.0.0
- Compatibility with Shopware 6.7.
- Support for the following languages: de-DE, en-GB, nl-NL, fr-FR, es-ES, fi-FI, nn-NO, sv-SE, cs-CZ, pt-PT, tr-TR, da-DK, it-IT, pl-PL, bs-BA
8.7.1
- The accordion element now interprets Twig.
6.32.0
8.7.0
- Added form builder logs which are shown in the admin.
- Added scheduled task for cleaning up logs after a certain period of time (changeable in plugin configs).
8.6.2
- Moved blocks Text four column and Show more text to ACRIS Blocks category.
7.23.3
7.23.2
- Optimised category reset content button alignment.
8.6.1
- Fixes category layout reset snippet.
7.23.1
7.23.0
- Added cms content reset functionality to category layout.
8.6.0
8.5.2
- Optimisation of the included form builder email template for umlauts.
8.5.1
- Optimization of the included form builder email templates.
8.5.0
- The countdown element has been expanded by several settings.
8.4.0
- The form fields in the Form Builder element can now set restrictions for other fields.
8.3.6
- Optimised plugin compatibility for product properties display in the description.
7.22.9
6.31.7
- Improved compatibility with other plugins for price display on the product page.
7.22.8
8.3.5
6.31.6
- Added help text to the new "playsinline" setting for the HTML video element configuration.
7.22.7
8.3.4
- Added setting for "playsinline" attribute to HTML video element.
7.22.6
6.31.5
8.3.3
- Added new border and text settings for Category box listing element.
7.22.5
- Fixed spacings and border styling for the Category Listing element in the storefront.
7.22.4
8.3.2
- Optimised administration snippets.
7.22.3
6.31.4
- Fixed drag and drop not working when using more than 16 images.
8.3.1
7.22.2
7.22.1
- Added banner count per slide setting for very large desktop viewport.
8.3.0
- Added possibility to define banner count for each slide in the ACRIS Banner slider element.
7.22.0
6.31.3
- Fixed possible issue with drag and drop not working for existing shopping experience elements.
8.2.1
- Fixed drag and drop functionality not working for ACRIS image gallery elements.
6.31.2
7.21.1
6.31.1
- Added missing replyTo plugin configuration for the form builder.
7.21.0
- Added new countdown element and block.
8.2.0
- Added new blocks for countdown and counter.
7.20.13
- The banner slider fade effect has been optimized.
8.1.1
8.1.0
- Added new countdown element.
8.0.3
- Fixed showing file upload info text on every input field.
- Fixed not displaying max file size.
7.20.12
8.0.2
- The banner slider fade effect has been improved.
7.20.11
7.20.10
- Fixed version compatibility.
8.0.1
- Fixed file accept on file input field in storefront.
7.20.9
7.20.8
- Changed version compatibility.
8.0.0
- Fixed compatibility.
7.20.7
7.20.6
- Fixed compatibility with shopware 6.6.9.0.
7.20.5
- Fixed possible issue when uploading own icons for shopping experience elements.
7.20.4
- The button width can now be set in the newsletter element.
7.20.3
- Fixed bug when uploading photos for elements with image upload functionality.
6.31.0
- Added a new configuration in the flow builder to select whether the form should be sent to the email address from the submitted form itself.
7.20.2
- A bug with the newsletter element has been fixed.
7.20.1
- Fixed extended image gallery thumbnail sizes.
7.20.0
- Added plugin config to add the form builder email, first and last name and add them as a reply address to the email sent.
7.19.11
- Fixed overlay not working for gallery if only one image is used.
6.30.4
- Performance optimization when using custom icons in shopping experience elements.
