CMS Erlebniswelten Pro - CMS / Erlebniswelten Blöcke, Elemente, Grid, Formular Builder
(7 reviews)
  • 18 different placeholders can be individually filled with elements
  • Product detail page can be completely customised - the essential functions have been broken down into individual elements for this purpose
  • Prefabricated blocks and elements that can be used universally in the shopping experiences
  • Many of the elements are configurable and can therefore be used in a variety of ways
  • Animations globally or individually for experience world elements
  • Extends the Shopware shopping experiences with numerous blocks and elements
  • From plugin version 6.8.1 (5.15.0 for Shopware < 6.5), blocks and sections can be controlled via rules
Over 70 useful CMS extensions for the Shopware experience:
1. ACRIS Columns Placeholder (empty layout (grid) blocks (here you can use all Shopware elements).
  • 1 column
  • 2 columns
  • 2 columns (40% / 60%)
  • 2 columns (60% / 40%)
  • 2 columns (25% / 75%)
  • 2 columns (75% / 25%)
  • 2 columns with spacing (33% / 42%)
  • 2 columns with spacing (42% / 33%)
  • 3 columns
  • 3 columns (50% / 25% / 25%)
  • 3 columns (25% / 50% / 25%)
  • 3 columns (25% / 25% / 50%)
  • 4 columns
  • 5 columns
  • 6 columns
  • 8 columns
  • 10 columns
  • 12 columns
2. ACRIS blocks
  • Note (Alert)
  • Banner Slider
  • Text Box / 5 Categories Box Slider
  • HTML Code
  • Headline (Headline)
  • Headline and image (right)
  • Headline and image (left)
  • Headline and image right (rounded with column offset)
  • Headline and image left (rounded with columns offset)
  • Image with Button Box
  • Masonry Image Gallery
  • Image Gallery Slider
  • Four Columns, Link Box
  • Newsletter (Subscription Box)
  • 2 columns, Teaser Box
  • Teaser full screen
  • Teaser side by side
  • Recommendation
  • Image full width
  • Image medium centered
  • Image small centered
  • HTML video upload
  • Formular Builder
  • Tabs
  • Button
  • Accordion
3. ACRIS form builder
Powerful form builder with many different field types including prefill functionality and hidden form fields.
Dependencies between fields in the form (from plugin version 8.4.0 for SW >= 6.6.9.0)
Input fields within a form can be hidden or concealed depending on the value of other fields.
Several restrictions can also be specified for each field. These are interpreted as an "OR" link.
Alternative recipients depending on the selected option in the form(from plugin version 7.7.0 for SW >= 6.6, 6.27.0 for SW >= 6.5)
This can be configured and used with maximum flexibility:
-> Via the Shopware Rule Builder
-> and with the Shopware Flow Builder.
Configuration instructions:
-> 2 new conditions are now available in the Rule Builder:
** ‘ACRIS Form Builder Field Value’
** ‘ACRIS form builder form with internal ID’
-> This can be used to create a rule: If form X and value Y selected.
-> This rule can be inserted in the Flow Builder and if this rule is true, an alternative recipient address can be entered there
4. ACRIS product detail (the product detail page was split into blocks and individual elements)
  • Product image - gallery (fixed) and buybox (25% 75%)
  • Product image - gallery large and buybox 75% 25%)
  • Product name
  • Manufacturer Logo
  • Price & Availability
  • Quantity & Shopping Cart Button
  • Product number
  • Manufacturer number
  • EAN Code
  • Height
  • Width
  • Length
  • Weight
  • Product features
  • Product variants
  • Product description and evaluation Extensions
5. ACRIS product listing
  • Product listing (adjustable how many products should be displayed in a row, depending on the display format)
  • Four columns, product boxes
6. ACRIS additional functions
  • Experience world (A (selectable) experience world is inserted as a block, this can be used e.g. on the product detail page or on the product overview)
7. (exchange) elements
(these can be used with many blocks)
  • Note (Alert)
  • Banner Slider
  • Button Box
  • HTML Code
  • Feature Box
  • Headline
  • Image
  • Image Gallery
  • Link Box
  • Teaser box
  • Recommendation
  • Placeholder
  • Newsletter
  • HTML video upload
  • Category box with image
  • Text Box
  • Product name
  • Manufacturer Logo
  • Product number
  • EAN-Code
  • Product features
  • Product listing
  • Product variants
  • Product description and reviews Extension
  • World of experience
  • Tabs
  • Button
  • Accordion
8. column customization for responsive design
For all ACRIS elements that are supplied in this plugin, there is the possibility to define the column width, column order and the define column spacing for different output devices.
These settings can be found under the block settings of the respective element. Here you can set the column width, column order and column spacing for various devices (tablet, phone, desktop) differently on the basis of a
a grid with 12 columns. An example: for the desktop display, the first column should take up 25% and the second 75% of the screen and on the tablet both columns should be 50%.
Animations (on scroll or in the visible area)
-> Animations can be configured globally for Shopping Experiences elements and product boxes via plugin settings
-> Animations can be customised individually for each experience world element
Depending on the settings, the animations only work when scrolling or can also be executed in the visible area.
Plugin extension:
From plugin version 6.8.1 (5.15.0 for Shopware < 6.5), blocks and sections can be controlled via rules. This means that page content can be displayed individually for customers or time periods.
  • Latest update: 29 April 2025
  • Publication date: 19 May 2022
  • Version: 8.7.0
Reviews (7)
Based on 7 reviews
CMS endlich einfach
by Christopher Bauer
14 May 2024 14:20
Ich habe das Shopware Plugin "CMS-Erlebniswelten" von Acris im Einsatz und bin äußerst zufrieden. Das Plugin bietet eine Vielzahl von Gestaltungsmöglichkeiten, die es einfach machen, attraktive und ansprechende Seiten zu erstellen. Besonders hervorzuheben ist die Benutzerfreundlichkeit – die Funktionen sind selbsterklärend und leicht zugänglich.
Was mich besonders beeindruckt hat, ist der überragende Support von Acris. Bei Fragen oder Problemen wurde mir schnell und kompetent geholfen. Der Support ist freundlich, gut erreichbar und hat immer eine Lösung parat.
Insgesamt kann ich das Plugin jedem Shopware-Nutzer empfehlen, der auf der Suche nach flexiblen und einfach zu bedienenden Gestaltungstools ist. Ein großes Lob an das Acris-Team für dieses hervorragende Produkt und den erstklassigen Service!
Blitzschneller Support
by FR
22 December 2023 13:09
Empfehlenswert in allen Belangen.
Must Have für SW6
by Dirk Messmer
15 December 2023 15:36
Super Erweiterung für die Erlebniswelten, tolle Elemente, schneller Support .. kann man nur weiterempfehlen
Toll Tool, sehr gut durchdacht
by Florian Weisser
31 October 2023 10:55
Macht Spass damit Seiten Layouts zu bauen.
Großartig!!! Besonders die Funktion
by Alexander Geller
21 September 2023 10:38
Acris bohrt mit dieser Sammlung an durchdachten Plugin-Elementen die Shopware-Standard Funktionen der Erlebniswelten enorm auf.
Als ich eher beiläufig im Kleingedruckten über den Punkt 5 "ACRIS Zusatfunktionen" gestolpert bin - schlug mein Herz bis zum Hals. Nach dem erfolgreichen Test konnte ich mein Glück kaum fassen und führte einen Freudentanz im Büro auf ;-)
Von dieser Funktion habe ich seit Ewigkeiten geträumt. Diverse Plugin-Entwickler haben auf meine Bitte, eine solche Funktion zu programmieren, abgewunken.
Ein riesengroßes Dankeschön an das Acris-Team: Ihr habt mich mit diesem Plugin sehr glücklich gemacht!! ;-)))
Weitere Acris Plugins stehen bereits auf meiner "MUST HAVE" Liste.
Mein persönlicher Plugin-Favorit
by Martin Wagner
14 August 2023 12:05
Neben vielen großartigen Erweiterungen und Tools, wie Rule und Flow Builder, Rabattaktionen etc. sind die Erlebniswelten für mich das herausragende Tool von Shopware. Mit diesem Plugin (und ein bisschen CSS) lassen sich die Möglichkeiten fast komplett ausreizen und Layout-Ideen relativ schnell und unkompliziert umsetzen.
Jede einzelne Block-Kategorie ist dabei an den Bedürfnissen für Anwender orientiert und so umgesetzt, dass man sich sofort damit zurecht findet.
Neben einer Vielzahl essenzieller Blöcke, wie Gallerie, Slider, Akkordeon und und und, haben mich die Produktdetails und Spaltenblöcke am meisten überzeugt. Damit ist es möglich eine Produktseite von Grund auf den eigenen Bedürfnissen und Kundenwünschen gemäß aufzubauen.
Wir haben einige Plugins von ACRIS im Einsatz, sind mit allen sehr zufrieden, aber dieses Plugin toppt alle. Hinzu kommt der großartige Support, der schnell, äusserst kompetent und sehr kundenorientiert arbeitet.
Hilfreiche Funktionen, sehr guter Support
by Michael Schorn
16 June 2022 15:45
Das Plugin erleichtert die Erstellung der Erlebniswelten erheblich. Bei einem Kompatibilitätsproblem hat der Support sehr schnell, freundlich und erfolgreich geholfen.
  • Ø-Rating: 4.9
  • Extensions: 156
  • Based in: Austria
