Saving and managing blocks and elements in Shopping Experiences + Shopping Experience Element copy & paste
  • Finish designing blocks / create templates for editors and save them for reuse
  • Configure elements and save as templates for editors to reuse
  • Block categories for easier administration / finding of blocks
  • Preview images for elements and blocks are individually possible
  • New: copy configured elements and paste them into other blocks
  • Individualise adventure blocks and save as a template.
  • Individualise elements of the world of experience and save them as templates.
  • Create block categories and make the individualised blocks available as templates.
  • Preview images for the new blocks as well as for the customised elements are possible for a quick overview.
  • Sequences for sorting can be selected in the admin of the template blocks
  • New: "Copy & Paste function" for configured elements - this makes it easy to copy and paste already configured elements when making layout changes.
Application scenario - for whom is this plugin intended?
There are numerous ready-made blocks and elements for the Shopware experience worlds - directly from Shopware but also from other agencies. These elements and blocks offer numerous setting options. In the Shopware standard, these settings cannot be saved for reuse.
This is exactly where our plugin comes in and saves your settings of the elements and blocks for reuse. So that you can continue to use the standard blocks and elements, we also save them. For the blocks, we offer the possibility to classify them in their own block categories, so that your prefabricated blocks are easy to find. We have also created the possibility to create and manage your own block categories.
New: Copy configured elements from experience world blocks and paste the copied element into another block.
Using the plugin
The easiest way to use our "Save and manage experience world blocks and elements" plugin is to use an example:
1.) Create an experience world (Shopware Standard)
      Content > Worlds of Experience > Create new layout > e.g. a landing page > Full width > Assign layout name
2.) Add a block (Shopware Standard)
     Add block > select block category > e.g. image & text > select block > e.g. two columns, centred image & text
3.) Change elements / content (Shopware Standard)
    Click on the text element and edit it with the cogwheel.
    Then carry out the settings (change / format the text in the tab Contents or set the vertical alignment under the tab Settings).
4.) SAVE elements / contents (ACRIS Plugin Feature)
    Click on the element to be saved - in this case our adapted text element - and click on the save symbol.
    A window opens in which a name of the element, the position of the element in the element list.
    Optionally, a preview image of the element can be added. Once the name has been given, the element can be saved.
    Then edit the other elements of the block and save them if desired.
5.) SAVE block (ACRIS Plugin Feature)
    Our plugin not only allows you to save elements, but also to save entire blocks (which can consist of several elements) for reuse or as a template.
    To do this, click on the save symbol in the block settings > a new window opens.
    A descriptive block name makes it easier to find the block if there are many blocks, as well as the position and the block category.
    We provide a new block category which can be used immediately: "ACRIS individual blocks" - you are welcome to create further block categories (see below).
   Optionally, you can upload a block preview image, which will then be displayed in the admin area as a block preview.
   Please do not forget to save the block.
Management of block categories / configured blocks / configured elements
For the administration of saved blocks, saved elements or for the creation of new block categories, we provide the following with our plugin:
Settings > Extensions > Saved Blocks and Elements.
    Block category:
    Block categories can be newly created or managed here.
    The plug-in already creates a new block category ""ACRIS individual blocks", this is added to the block categories below in the worlds of experience.
    Blocks
    Here you will find all the blocks that have been created and saved in the worlds of experience.
    Elements
    Here you will find all the elements you have created and saved in the worlds of experience.
Note:
The plugin is not compatible with the DREISCHILD CMS Professional plugin: https://store.shopware.com/dreis75949548131/cms-professional.html
  • Latest update: 9 April 2025
  • Publication date: 17 February 2022
  • Version: 3.0.4
  • Ø-Rating: 4.9
  • Extensions: 156
  • Based in: Austria
