Filter Pro - Filter as slider, category filter in search, number of products
Hide filters, sort filters and move filters to "show more" are essential features. This plugin allows this in a simple way and is fully integrated into the Shopware Standard.
Compatible with:
6.2.0 - 6.6.10.5
Includes:
Using the plugin
It will be added in Shopware Admin 2 new entry:- Settings -> Plugins -> Filter Configurations (basic configuration of the Shopware standard filters)
- Catalogs -> Properties -> Select a filter -> New Properties section as filter in the product listing (for the property filters)
Hint:
Shopware standard filters (like price, manufacturer, ratings etc.) are configured here:Settings -> Plugins -> Filter configurations
In this area a filter "Product Properties" is also listed - this "block" can be completely hidden (or moved to more filters).
If you want to hide individual "Product Properties", you must do so here:
Catalogues -> Properties -> select a filter -> New area Properties as filter in the product listing
from plugin version 3.1.x
The store search can be extended (activation in the plugin settings) by a category search.
This function makes sense if a search should be limited by the user to a category, so that the search results are better.
from plugin version 6.2.0
A min-max slider can be integrated into the filter.
Example of use: Customer is looking for a table length between 2m - 2.20m.
- Available: English, German
- Latest update: 19 May 2025
- Publication date: 19 March 2021
- Version: 9.0.1
- Category: Search & Filter
Reviews (7)
Super aber mega teuer
4.0
by Manu
4 December 2024 10:51
Macht was es soll, ist aber halt mega teuer.
Functionality
Usability
3.0
Documentation
3.0
Super Plugin
by Anke
13 September 2023 15:24
Das Plugin stellt Funktionen zur Verfügung die im Standard leider nicht zur Verfügung stehen. Es ist einfach zu konfigurieren und der Support reagiert super schnell. Hatten einen Verbesserungsvorschlag und nach einem Tag stand schon eine neue Version zum Download zur Verfügung. Danke!
Functionality
Usability
Documentation
Freundlicher Support, schnelle Reaktion
by Atilla Boz
10 August 2022 23:54
Ich hab zuerst die Einstellung nicht gefunden - der Support hat zügig geantwortet und die Welt war wieder in Ordnung. :) Praktisches Plugin zur Sidebar-Optimierung.
Functionality
Usability
Documentation
Super Support
by A. Harbott
1 July 2022 14:26
Fehler in Kombination mit einem anderen Plugin wurde zügig gefunden und behoben. Vielen Dank für den tollen und freundlichen Support.
Functionality
Usability
Documentation
Funktioniert perfekt und sehr guter Support
by Daniel Haug
7 April 2022 09:37
Ein anderes Plugin wurde nicht mehr angezeigt nach der Installation. Innerhalb kürzerster Zeit gab es ein Update. Nun funktioniert alles super.
Functionality
Usability
Documentation
Super Plugin, schneller Support
by Michael Wetzel
18 February 2022 13:50
Das Plugin erfüllt für unseren Zweck voll und ganz die Funktionalität mit der Filterdarstellung. Sehr rasche Antwort vom Support.
Functionality
Usability
Documentation
Sehr schneller Support | Tolles Plugin
by M. W.
11 February 2022 10:51
Anfangs gab es Schwierigkeiten, wurde durch den Support aber rasant gelöst. Sehr freundlicher Support. Wir sind zufrieden.
Functionality
Usability
Documentation
Bronze Partner -
- Ø-Rating: 4.9
- Partner since: 2015
- Extensions: 156
- Based in: Austria
- Speaks: German, English
- Response time: Very quickly
