Design header and footer with Shopware worlds of experience (and with rules)
The plugin allows you to design the header and footer using experience worlds you have created yourself. One or more experience worlds can be assigned to the header or footer depending on different rules (e.g. different customer groups or time periods), sales channels and screen sizes.
From plugin version > 3.26.x it is also possible to define individual headers & footers for the checkout.
Instructions
1.) Install and activate the plugin (no plugin configuration is required).
2.) Create an Shopping experience world (header or footer), proceed as follows:
Showare Admin: Content > World of Experience > Create new layout button > Select header pages or footer pages.
Select Header Pages or Footer Pages > Full Width > Enter Layout Name (e.g. Consumer)
then create the world of experience: Click right on + then select block category ACRIS Header Layout (or ACRIS Footer Layout) and select a header (or footer).
As a rule, some information is required for the elements. To do this, click on the cogwheel for the elements and enter the required information.
(for the header: at least the entry point for the navigation must be entered.)
Note: If an error occurs when saving, then various obligatory entries have not been made in the block.
3.) Display the header (or footer) by means of RuleBuilder, Category or Produkt Detail Page for this purpose
Shopware Admin: Settings > Extensions > World of Experience Layouts > Header (or Footer) > Add Header
in the section General:
>> Specify internal name (e.g. Consumer Header)
>> Priority can remain at 10 in the first step, the higher the number, the higher the priority (only relevant if multiple headers are created)
>> Exclude other headers with lower priority (can remain active - this is relevant if multiple headers are created)
>> click active
>> visible for the following screen sizes (all selected by default, if required you can create different headers for the individual screen sizes)
in the Layout section Assigned World of Experience Layout:
>> Assign the header (or footer) layout created under 2.) (or create a new one)
>> Select Stickey Header Mode
in the section Display Conditions you can define the rules how / if the header will be displayed, for this purpose
>> Optional: Assigned Rule (in the Rule Builder you can create the rule and assign it here)
If no rule is assigned, then "always display" applies.
>> Sales channels: Select in which sales channel the header should be displayed.
>> Optional: Additional restriction to products / categories
>> Save and switch to the frontend - you may have to clear the cache to see a change.
If you have any questions about the plugin, feedback or enhancement requests, please use the Shopware account and create a support request there - this is the only way we can ensure prompt processing.
- Available: English, German
- Latest update: 3 June 2025
- Publication date: 31 August 2021
- Version: 8.0.1
- Category: Header & Footer
Reviews (2)
Top Plugin um Header und Footer anzupassen.
Flexible plugin to build custom header and footer based on shopping experiences with predefined block layouts and well-built general logic.
Bronze Partner -
- Ø-Rating: 4.9
- Partner since: 2015
- Extensions: 156
- Based in: Austria
- Speaks: German, English
- Response time: Very quickly
