SEO Tools for Professionals
(4 reviews)
  • Simple SEO setup incl. snippets and robots.txt
  • Flexible redirects with exact URL or RegEx
  • Additional useful SEO tools for search engine optimization
  • Preview the snippet
  • Pre-made snippet for immediate use
  • Easy customization of the snippets
  • Redirect URL with intuitive handling
  • Define SEO redirects via Regular Expressions (From version 1.4.1)
  • Automatic output of the JSON LD Rich Snippets
  • Create Robots.txt (in the plugin configuration)
  • Easily switch between "NoIndex,NoFollow" / "Index,Follow" - especially important when setting up the webshop (in the plugin configuration)
SEO Tools is your professional SEO tool for your Shopware shop. Automated settings increase the ranking, visibility and CTR for both the articles and the categories.
New features:
  • From 3.1.0: Storage of the 404 error page incl. how often clicked, last call and last referer.
  • From 4.4.0: Optimisation of the category displayed in the breadcrumb
User guide
Manual (PDF)
Functions
Snippets
A snippet is the preview of the content of a website in the search results. The snippets are taken from the title and description and displayed in the search result list (SERP). The more information contained in the title and description, the better Google can access this information. The CTR (click-through rate) on an article or category is increased if a call to action and special characters are included in the snippets. Both title and description can be assigned automatically.
  • Call to Action
    A call to action is a request to take a certain action. In the case of online shops, these are usually buying impulses (e.g. buy cheap now / order cheaply immediately / buy free of shipping costs / etc.). A “call to action” demonstrably increases the willingness of potential customers to click on a search result.
  • Special Character
    You have probably seen the large arrows or ticks in the search results several times. These special characters attract more attention than plain text and force the searcher to focus on them.
  • Variable
    Further shop variables such as Implement stock level, price or manufacturer.
  • Templates
    After installation, ten pre-made snippet templates for articles and categories are already in the administration. There new templates can be created or existing ones can be changed. Individual snippets can then be created for each article and each category.
  • Preview
    A preview, which is similar to the results on Google, makes it easier to create the snippets.
Redirect URL
With this plugin you can easily create and manage SEO-compliant URL redirects with 301 or 302 status code in Shopware Administration.
NEW FEATURE FROM VERSION 1.4.1
As of version 1.4.1, this plugin allows you to define SEO redirects using Regular Expressions.
A Regular Expression (or Regex) is a group of characters used to find a pattern within a piece of text.
In the context of redirects, a simple URL match will correspond to exactly one URL. A regex URL can match many URLs.
In addition to matching many URLs, a regular expression can extract information from the source URL and copy it into the destination URL.
An example for better understanding:
A redirect with the source URL /my-url will only ever match requests for /my-url.
A redirect with the source URL /meine-url/.* will match requests for:
    /meine-url/a
    /my-url/b
And so on.
The important part of /my-url/.* is .*. This is the regular expression part of the URL and is equivalent to saying "take /my-url/ followed by any string".
Although this is very useful for a lot of redirects, this feature is more for advanced users, as creating these regular expressions requires further knowledge. But you don't have to use regular expressions for the redirects, you can still use redirects with an exact match of the URL. If both variants are stored for a URL, exact matches for a redirect are always searched for first. If no exact match is found, regular expressions are checked in the second step.
A guide to the regular expressions including a link to a manual and a cheat sheet can be found in the Shopware admin area at the redirects.
Pass rich snippets to Google in JSON-LD format. Rich snippets are a special form of snippet. They are used to transfer relevant information to Google. If you see the stock level and the price of a product in the search results, then these data were passed with rich snippets. This function is implemented in Shopware 6 and the rich snippets are transferred with microdata. However, W3C and Google recommend using JSON-LD. With the ACRIS SEO Tools plugin, the data is transferred in JSON-LD format. You are therefore prepared for the future.
The SEO Tools plugin from ACRIS offers even more options. The search results on Google can be further refined by entering specific information about your industry and your company.
By activating the "Sitelinks Search Box" you give Google the option of displaying your own search in the search. The "Sitelinks Search Box" is a search box that appears within a snippet in the Google SERPs. In this way, users can search for content directly in the search result list on the desired page.
Of course, there is no guarantee that Google will also display the search box. You just create the possibilities. The final decision is always made by Google's algorithm.
Robots settings
With the robots settings you can define the visibility for search engines. In this way, you can determine whether Google should include individual articles or individual categories in the index. With the JSON LD Rich Snippets section it is also possible to make the entire shop not indexable for Google.
Breadcrumb category (from 4.4.0)
If the plugin is active, the category specified in the breadcrumb for product pages is always the category assigned to the product with the lowest level. The exception is if a main category has been defined for the product for the sales channel.
At Shopware default a random category is always displayed.
It is also possible to use a plugin setting to specify categories that are ignored when creating the product breadcrumb. This also applies to all their subcategories. For example, a "Brands" or "Sale" category could be specified here.
  • Latest update: 5 November 2025
  • Publication date: 25 May 2020
  • Version: 5.2.7
  • Category: SEO Optimization
Reviews (4)
Based on 4 reviews
Top Plugin
by Jörg Schuck
6 August 2025 10:30
Bedient alle unsere Use-Cases bisher. Und bei Problemen ist der Support schnell und freundlich.
Sehr empfehlenswert.
Umfangreiches Plugin, schneller und kompetenter Support, professionelle Lösung meines Problems – absolut empfehlenswert!
by Alex
22 July 2025 11:18
Das Plugin ist sehr umfangreich und bietet viele nützliche Funktionen.
Besonders hervorheben möchte ich den Support: Auf mein Problem wurde sehr schnell reagiert, kompetent darauf eingegangen und eine professionelle Lösung innerhalb kürzester Zeit umgesetzt.
Ich bin rundum zufrieden und kann sowohl das Plugin als auch den Support uneingeschränkt weiterempfehlen!
Top Modul & erstklassiger Support
by Benedikt Zöllner
12 May 2025 08:21
Das SEO-Modul überzeugt mit klaren Funktionen und echtem Mehrwert für unsere Sichtbarkeit. Besonders begeistert hat uns der Support: schnell, kompetent und offen für neue Ideen. Feature Requests wurden in Rekordzeit umgesetzt – so fühlt sich echte Partnerschaft an. Absolute Empfehlung!
TOP sehr zu empfehlen ⭐️⭐️⭐️⭐️⭐️
by Ursula Rohde
21 January 2025 16:52
Das Plugin ist MEGA und der Support ist nicht zu übertreffen.
Bevor dieses Plugin auf den Markt kam hatte ich ein Konkurrenzprodukt mit dem ich nicht zurecht kam. Das ACRIS Plugin hingegen ist klar und leicht verständlich strukturiert und es bietet alle nur wünschenswerten Möglichkeiten.
Ich hatte bei ACRIS angefragt ob es eine Möglichkeit gebe, die Robots Einstellungen von Varianten per Mehrfachänderung vornehmen zu können.
Dieser Wunsch wurde tatsächlich zeitnah erfüllt. Hammer. Ich habe bereits 7 ACRIS Plugins, alle sind super durchdacht, zuverlässig und haben dazu noch einen Top Service.
  • Ø-Rating: 4.9
  • Extensions: 165
  • Based in: Austria
