Order confirmation link in email does not work after 30 days - now adjustable
  • Adjustable, how long the link from the order confirmation is callable.
  • Enable the function to load orders based on the maximum order age
  • Maximum age of incoming orders (days) adjustable
Situation
In Shopware Standard, an order confirmation is sent after an order is placed, like the following content:
You can check the current status of your order at any time by clicking this link:
https://www.ShopDomain.com/account/order/sg4y1WS3lJOq8J4y-RVXCZip3gHYyeAw
You can also use this link to edit the order, change the payment method or make a payment afterwards.
Problem
If the recipient clicks on this link after 30 days, the user either receives a blank page or the login does not take the user to the desired order.
Cause / Solution
The reason for this behavior is a Shopware hardcoded behavior that the "SessionLink" loses its validity after 30 days.
The ACRIS plugin now allows to set the period until the link is no longer valid - in days.
  • Latest update: 9 April 2025
  • Publication date: 14 March 2022
  • Version: 3.0.0
  • Ø-Rating: 4.9
  • Extensions: 156
  • Based in: Austria
