SEO Redirect (Redirect 301 / 302) Pro
Import / Export function is available
Under Settings > System > Import / Export > a corresponding profile is available.The easiest way is to create a redirect and perform an export.
Hint: Note the separator and the ID (first column) is only required if existing redirects need to be updated. Leave this column empty for new redirects.
Count of redirects from plugin version 3.2.x
The number of redirects, the time of the last redirect and the last referer were added.
Performance option (from 3.3.x)
If desired, a setting is possible in the plugin configuration that before a possible redirect check is checked whether the requested page produces a 404 page and only then in the redirect table is checked whether an entry exists. This improves the performance of the website if a lot of redirects are created.
Why SEO redirects
- No loss of ranking with a relaunch
- No loss of ranking due to product changes
- Temporary forwarding for advertising campaigns
Configuration
Administration: Via Settings > Plugins > SEO Redirect
URLs: Insert old URL and redirection destination with copy and paste
Protocol (http/https): Is automatically recognized, but can be entered with the URL
Setting status code: Temporary (status code 302) or permanent (status code 301)
Activation: Active / not active
Overview: List of all redirects with URLs, status and active
Search
function: Via the Shopware search function
NEW FEATURE FROM VERSION 2.3.1
As of version 2.3.1, this plugin allows you to define SEO redirects using Regular Expressions.
A Regular Expression (or Regex) is a group of characters used to find a pattern within a piece of text.
In the context of redirects, a simple URL match will correspond to exactly one URL. A regex URL can match many URLs.
In addition to matching many URLs, a regular expression can extract information from the source URL and copy it into the destination URL.
An example for better understanding:
A redirect with the source URL /my-url will only ever match requests for /my-url.
A redirect with the source URL /meine-url/.* will match requests for:
/meine-url/a
/my-url/b
And so on.
The important part of /my-url/.* is .*. This is the regular expression part of the URL and is equivalent to saying "take /my-url/ followed by any string".
Although this is very useful for a lot of redirects, this feature is more for advanced users, as creating these regular expressions requires further knowledge. But you don't have to use regular expressions for the redirects, you can still use redirects with an exact match of the URL. If both variants are stored for a URL, exact matches for a redirect are always searched for first. If no exact match is found, regular expressions are checked in the second step.
A guide to the regular expressions including a link to a manual and a cheat sheet can be found in the Shopware admin area in the redirects.
Applications:
Website relaunch - previous pages are redirected to the new pages (permanent redirection). Thereby no ranking losses occur.
Changes in the product range - a well ranking category page has to be dissolved due to a product change. With a 301 redirection you can refer to the new category page.
Short-term advertising - a well ranking category page can temporarily redirect to a special advertising page to present the offer to more customers.
- Available: English, German
- Latest update: 22 October 2025
- Publication date: 29 August 2019
- Version: 6.1.4
- Category: SEO Optimization
Reviews (4)
Mächtiges Tool und bester Support!
Das Beste ist jedoch der supernette und superschnelle Support! Innerhalb eines Tages wurde mein Problem mit einer neuen Version gefixt, wow.
(fast) perfekte Erweiterung
Dennoch haben mich die Weiterleitung fast in den Wahnsinn getrieben. Lauter Umleitungsfehler nach export aus sw5 und import nach sw6.
Grund: das was in sw5 erlaubt war, darf in sw6 nicht sein:
Beispiel: Urls kommen von sw5 ohne vorangestellter Domain
alt: /product0815englisch nach neu: /en/product0815englisch läuft in eine endlosschleife.
Das war in sw5 ok, hier nicht mehr.
Lösung: Angabe der vollständigen URL mit Domain.
Das fehlte mir in der Anleitung zum Wahnsinn. Oder vielleicht gelingt es dem Team das im Plugin abzufangen.
Besten Dank für den kürzlichen super Support dazu.
funktioniert wunderbar
Acris macht einfach gute und funktionierende Plugins!! Danke
Bronze Partner -
- Ø-Rating: 4.9
- Partner since: 2015
- Extensions: 163
- Based in: Austria
- Speaks: German, English
- Response time: Very quickly
