Persistent shopping cart (logged in even across devices)
(2 reviews)
  • Permanent shopping cart for registered users: The shopping cart is available across browsers and devices.
  • Log in / log out / log in: The shopping cart always remains constant
  • Shopping cart is also saved in a cookie for guest users
  • Permanent shopping cart for users who register.
  • Registered users have access to the same shopping cart across all browsers and devices
  • Permanent shopping cart for guest (unregistered) users by saving in the cookie
  • Items that are placed in the shopping cart before a registered user logs in will be added to the "old" shopping cart during the course of a login.
Permanent shopping cart for users who log in / register also across devices.
With "Guest User" the shopping cart is saved in a cookie.
Use Case #1 (User registers during checkout and cancels the purchase process)
  • A user, placed an article in the shopping cart.
  • In the course of the checkout the user creates a user account
  • the user cancels the purchase process and closes the browser
  • At the next visit, after a successful login, the user's last shopping cart is loaded again.
Use case #2 (registered user logs in with another device)
  • A user works at the PC, adds an item to the shopping cart and logs in, for example, during checkout.
  • The user aborts at the PC and logs in later with his account on the mobile phone and can simply complete his shopping cart there.
Use Case #3 (Guest User)
  • the user closes the browser.
  • The next time the user visits the shop, the shopping cart is loaded (because it is stored in the cookie)
  • Latest update: 9 April 2025
  • Publication date: 17 July 2020
  • Version: 3.2.0
Reviews (2)
Based on 2 reviews
sehr gutes Plugin für eine elementare Shop Funktion
by Nico Hartenstein
12 October 2020 11:32
Dies ist das einzige Plugin für den Warenkorb das gleich funktioniert hatte... 100000x Danke macht weiter so.
by Tobias Schneider
20 August 2020 14:02
  • Ø-Rating: 4.9
  • Extensions: 156
  • Based in: Austria
