PDF print view for shopping cart, order completion, order confirmation
Create your own print views for shopping cart, order completion page or order confirmation page. Customizable and if necessary rule-controlled to fade in. Optional individual steps.
Compatible with:
6.4.14.0 - 6.6.10.5
Includes:
Purpose of the plugin
Different print views can be provided for the shopping cart, the order overview page and / or the order confirmation page. For this purpose, it is possible to define your own views of the printouts in the administration interface of the plugin. If a USER clicks on the PRINT BUTTON in the frontend, then a PDF is generated, this can then be printed or saved without any problems.
Create print views / customize predefined print views
Shopware Admin: Settings > Extensions > Print View > Print View (add print view or customize existing).
With the plugin we already provide 2 print views, these can be customized or new print views can be created.
- Standard cart & checkout (shopping cart and order summary page print template)
- Standard confirm (order confirmation print template)
The following configurations are available for the print views
Configuration section
- Internal name: used to distinguish the print views
- Active: active or not active
- Priority: the higher the number, the higher the priority. This is relevant because only one print view can be used at a time, the one with the highest priority is used.
- Rule: RuleBuilder rules can be assigned here. The print view will always be displayed if one of the specified rules matches (OR operation).
If no rule is selected, it will always be displayed. Examples would be narrowing down to a specific customer group.
(Please note that not all RuleBuilder rules that are technically possible can be used in this context).
- Display of the print view on the pages: Currently there are 3 areas where a print function can be displayed:
- Shopping Cart Overview, Order Confirmation, Order Completion.
Display settings section
- Header layout: Use store logo in header | Use header from mail template | Use custom header | Use no header
- Text to be displayed between header and shopping cart information: HTML formatted text incl. variables is possible
see https://docs.shopware.com/de/shopware-6-de/einstellungen/e-mail-vorlagen#variablen-im-mail-text
- Text to be displayed between shopping cart information and footer: HTML formatted text incl. variables is possible
- Footer layout: use page number in footer | use footer from mail template | use custom footer | use no footer
Settings options (plugin configuration)
Extensions > My Extensions > ACRIS Print View > Configurations- Sales channel:Different settings can be configured for each sales channel
- Print button display: Shopping cart overview:
Show under shopping cart button or not - Print button display: Order completion
Show top or do not show - Print button display: Order confirmation:
Show at top or do not show - Print Button
Show text
Show icon
Show icon and text - Print button text: Print
This is a text module and can be changed or translated into other languages if needed - PDF Name: %SalesChannelName%_Quotation_%date%
This is a text module and Twig variables can be used - only for experts use !
- Available: English, German
- Latest update: 14 May 2025
- Publication date: 13 October 2022
- Version: 5.0.0
- Category: Checkout / Cart process
Bronze Partner -
- Ø-Rating: 4.9
- Partner since: 2015
- Extensions: 156
- Based in: Austria
- Speaks: German, English
- Response time: Very quickly
