EU Cookie Policy Pro + Auto Cookie Detection (SW6) + Load scripts only after approval + Google Consent Mode V2 support
(32 reviews)
  • Recommended for every webshop to improve the EU Cookie Policy
  • From Version 5.0.0: (Tracking) Scripts only load after approval
  • Automatic cookie detection & activation / deactivation of individual cookies or cookie areas in the shopable / disable single cookies or cookie groups in the shop
  • Cookie administration and grouping of cookies by functional groups
  • Individual styling of the cookie groups in the plugin config
  • Google Consent Mode V2 support as well as GA4 and Google Ads (from plugin version 5.3)
  • Scripts can now only be loaded after approval (create new cookie, insert script, determine script code position (head, body)).
  • Selection of the cookies in the storefront
  • Change between modal window and classic cookie notice
  • Cookies are only allowed after acceptance in the shop
  • Automatic cookie detection per language- or subshop
  • Cookies backend administration
Supports Google Consent Mode V2 from version 5.3 (see below for documentation and demo container)
Recommended by the IT-Recht Kanzlei Munich: https://www.it-recht-kanzlei.de/rabatt-mandanten-eucookierichtliniepro-shopware.html
Improves the EU Cookie Policy compliant use of your webshop.
Since Shopware 6 can not prevent cookies from external scripts (eg Google Analytics) and thus tracking is also possible without accepting, this plugin is nevertheless urgently needed.
  • Non-functional cookies of the shop domain are only allowed in the shop as soon as the user accepts the cookie hint.
  • The cookie hint allows the user to activate / deactivate single cookies or whole cookie groups individually.
  • Cookies unknown to the plugin will be recognized automatically. These can then be titled by the shop owner and activated for selection in the store. Publicly known cookies (such as Google Analytics, Facebook Pixel, Amazon Pay, Livezilla, Cloudflare, Emarsys and many more) are automatically added to the cookie hint.
  • Cookies are automatically assigned to the recognized sales channel and only displayed there in the notice.
  • In the plugin settings you can switch between two layout options (Classic cookie note and modal window - since version 1.1.0).
  • Shop customers can adjust cookie settings after accepting (to set up the feature, see the installation instructions).
  • Buttons "Accept only functional cookies" and "Accept all cookies" can be to the note by plugin configuration if required.
  • from version 5.0: Scripts can now be loaded after approval - to do this, create a new "cookie" and fill in the corresponding fields.
  • New from version 5.3: Google Consent Mode V2 support
Technical functioning
The plugin recognizes all cookies set via HTTP or via Javascript from an internal (e.g., Shopware CSRF token) or externally loaded script (e.g., Google Analytics). All cookies that are not set for the shop domain and set by an external loaded resource (eg iFrame integration) for an external domain (eg www.paypal.com) can not be recognized by the plugin due to the same origin policy (browser security guidline) and can not be prevented. As an example, this concerns payment bindings loaded via iFrames (e.g., Paypal Express Shopware plugin).
Please note
The Plugin manufacturer assumes no liability for the complete DSGVO conformity and no claim to legal certainty can be asserted. In particular, it should be noted that each case is to be considered separately and does not replace individual legal advice.
Information about implementing Google Tag Manager
https://www.acris.at/media/77/32/3c/1709126654/SW6_Doku_Cookie-Richtlinie-Pro_Tag-Manager_V61_EN.pdf
Container template for the import into the Google Tag Manager (please unpack ZIP archive)
https://www.acris.at/media/d0/e3/05/1745493382/GTM_Container_Vorlage_bitte_entpacken_v5.zip
  • Scripte, Bilder, iFrames und Links einbinden (im HTML Code)  (wenn es nicht möglich ist, Scripte wie vorgesehen im Cookie Manager einzubinden)
    Zuerst ein neues Cookie anlegen und dann kann die CookieID entsprechend verwendet werden:
    LEIDER IST DER BEISPIELCODE HIER NICHT SICHTBAR - bei Bedarf kann der Beispielcode via Supportanfrage bei uns angefragt werden !
    • Image
      Vorher:
      <img src="https://www.acris.at/media/b0/a0/69/1657629899/ACRIS_Logo_Original_2022_RGB_ohne_Claim.png">
      Nachher:
      <img data-src="https://www.acris.at/media/b0/a0/69/1657629899/ACRIS_Logo_Original_2022_RGB_ohne_Claim.png" data-acriscookie="true" data-acriscookieid="AcrisTestIDd" src="">
    • Iframe
      Vorher:
      <iframe src="https://www.youtube.com/embed/v2AC41dglnM" width="560" height="315"></iframe>
      Nachher:
      <iframe data-src="https://www.youtube.com/embed/v2AC41dglnM" data-acriscookie="true" data-acriscookieid="AcrisTestID" src="" width="560" height="315"></iframe>
    • Skript direkte Einbindung
      Vorher:
      <script type="text/javascript"> console.log("test cms"); </script>
      Nachher:
      <script type="text/plain" data-acriscookie="true" data-acriscookieid="AcrisTestID"> console.log("test cms"); </script>
    • Skript Einbindung über src
      Vorher:
      <script type="text/javascript" src="https://www.w3schools.com/js/myScript.js" />
      Nachher:
      <script type="text/plain" data-acriscookie="true" data-acriscookieid="AcrisTestID" src="https://www.w3schools.com/js/myScript.js" />
    • Link
      Vorher:
      <link target="_blank" rel="noopener nofollow" href="https://fonts.googleapis.com/css?family=Kanit:400" type="text/css" >
      Nachher:
      <link data-target="_blank" rel="noopener nofollow" href="https://fonts.googleapis.com/css?family=Kanit:400" data-acriscookie="true" data-acriscookieid="AcrisTestID" type="text/css" >
    Für "img" oder "iframe" gibt es auch die Möglichkeit einen alternativen Text anzuzeigen.
    • Es muss ein Element mit der Klasse "acris-cookie-info", direkt danach eingefügt werden. Bespiel.:
      <img data-src="https://www.acris.at/media/b0/a0/69/1657629899/ACRIS_Logo_Original_2022_RGB_ohne_Claim.png" data-acriscookie="true" data-acriscookieid="test-id" src=""> <div >Externe Inhalte werden nach der Bestätigung des Datenschutzhinweises geladen.</div>
    • Oder ein Info Text - Beispiel.:
      <img data-src="https://www.acris.at/media/b0/a0/69/1657629899/ACRIS_Logo_Original_2022_RGB_ohne_Claim.png" data-acriscookie="true" data-acriscookieid="test-id" src=""> <div role="alert"> <div > <div >Externe Inhalte werden nach der Bestätigung des Datenschutzhinweises geladen.</div> </div> </div>
    • Mit dem ACRIS CMS Modul und dem HTML-Element lässt sich dann auch noch schön Twig Code verwenden. Beispiel:
      <img data-src="https://www.acris.at/media/b0/a0/69/1657629899/ACRIS_Logo_Original_2022_RGB_ohne_Claim.png" data-acriscookie="true" data-acriscookieid="test-id" src=""> <div > {% sw_include '@Storefront/storefront/utilities/alert.html.twig' with { type: "info", content: "Externe Inhalte werden nach der Bestätigung des Datenschutzhinweises geladen." } %} </div>
  • Integrating scripts via other plugins / apps
    1. A cookie must first be created in the admin (Settings > Extensions > EU Cookie Policy Pro > Cookies). The cookie ID can be: "my_cookie". The cookie must have a default value entered. In our example, this is the value 1.
    2. The following script can then be inserted in the other extension:
    import CookieStorage from 'src/helper/storage/cookie-storage.helper';
    init();
    function init() {
     const cookie = CookieStorage.getItem('my_cookie');
     if(cookie === '1') {
     loadMyScript();
    function loadMyScript() {
     const script = document.createElement('script');
     script.async = true;
     script.src = 'https://www.my-script.com/script.js';
     document.body.appendChild(script);
    Translated with DeepL.com (free version)
  • Latest update: 15 May 2025
  • Publication date: 10 February 2020
  • Version: 9.1.2
  • Category: Special features
Reviews (32)
Based on 32 reviews
4.9 Documentation
Klasse Plugin mit super Support
by Andreas
25 March 2025 09:34
Das Plugin an sich ist schon super. Einfach zu Bedienen und dank der schlüssigen Dokumentation auch gut zu verstehen. Der Support von ACRIS ist dazu schnell, sehr kompetent und überaus freundlich.
Gutes Plugin und schnelle Reaktionszeit beim Support
by Tobias
14 March 2025 19:11
Sehr empfehlenswert! Gutes Plugin. Schnelle Reaktionszeit und kompetenter Support.
4.0 Documentation
Super Plugin mit noch besserem Support
by Chris Vö
13 March 2025 09:45
Es gibt sie doch noch: kompetente Agenturen/Mitarbeiter wie Julian bei denen man das Gefühl hat dass Sie einem auch wirklich helfen wollen, die sich Mühe geben und vor allem super zeitnah sich darum kümmern. ACRIS ist eine davon! On Top noch ein hervorragendes Plugin was im Zusammenspiel mit dem ACRIS GTM und Statistik Add on tut was es soll. Ich kann ACRIS uneingeschränkt weiterempfehlen.
Alles wunderbar :)
by Angelika Bober
27 November 2024 15:01
Absolute Klasse
by Nicolas
4 November 2024 14:27
Toller Support, schnell er kümmert sich eifrig um das Problem.! GERNE weiter!
Sehr guter Support
by Andreas Märkle
23 October 2024 12:14
Plugin-Hersteller reagiert schnell und bietet Hilfe bei Fragen und Problemen.
Gutes Plugin mit sehr gutem Support
by Bresser GmbH
18 April 2024 09:38
Das Plugin funktioniert wie es soll und die Dokumentation ist ebenfalls sehr detailliert. Nach anfänglichen Schwierigkeiten von unserer Seite konnte uns der Support schnell weiterhelfen.
Sehr gutes Plugin
by Constantin
17 April 2024 12:19
Ein wirklich sehr gutes Plugin und funktioniert im Zusammenspiel mit Plugins von Drittanbietern. Der Support ist schnell und konnte alle Anliegen zur vollsten Zufriedenheit lösen. Volle Empfehlung.
by Klassen
15 March 2024 10:51
Das Plugin entspricht unseren Erwartungen und der Support reagiert auch sehr schnell auf Anfragen.
Plugin funktioniert im Gegensatz zu anderen
4.5
by Moira
28 February 2024 18:26
Funktioniert bei uns besser als das hochpreisige Produkt, welches wir jetzt gekündigt haben. Problem war bei uns die fehlende Umsatzmessung für E-Commerce und Conversions. Mit diesem Plugin funktioniert nun alles.
3.0 Documentation
  • Ø-Rating: 4.9
  • Extensions: 156
  • Based in: Austria
