Flow Builder extension: Time delay (minutes, hours, days)
(5 reviews)
  • Insert new delay action into the flow
  • Clear management of all delays
  • Supplied flows, rules and e-mail templates
  • Flow Builder action: Time delay by minutes, hours or days possible
  • List of triggered flows waiting to be processed (after which they are removed from the list)
  • Several samples of useful flows, Rule Builder Rules and an e-mail template for demo purposes are included
  • Logs older than the defined period can be deleted automatically
The Flow Builder is a useful and powerful tool for automated workflows and business processes. However, in the standard version, the option to define delayed functions is missing.
We have therefore developed a plugin that offers the following functions:
Add a new delay action to the flow
To insert a delay into the flow, this plugin allows you to add a new action. This can then be configured as desired. Minutes, hours, and days are available for the delay.
In addition to the General and Flow tabs in the Flow Builder, the plugin adds an additional tab called the Delayed Sequences tab. Here all used delays are displayed and the settings can be specified. More details can be found in the configuration instructions.
Included flows, rules and email templates
The plugin comes with several useful flows, rules, and email templates. A detailed description can be found in the configuration instructions.
  • Latest update: 9 December 2025
  • Publication date: 24 May 2023
  • Version: 4.1.3
  • Category: Administration
Reviews (5)
Based on 5 reviews
Einfach super!
by Philipp von Wedel
14 March 2025 09:40
Das Team von Acris kommuniziert völlig umkompliziert und bietet schnelle Hilfe.
Ich würde beim Support sogar mehr Sterne geben, wenn das möglich wäre.
Da können sich Andere eine Scheibe von abschneiden.
TOP! Grüße nach Linz
Idealer Plugin für die Automatisierung des Shops
by Kacper
10 July 2024 08:46
Am Anfang hatte ich einige Probleme mit der Ausführung, der Team von ACRIS hat mir aber freundlich und sehr schnell geholfen um das Problem zu beheben. Ich kann es weiterempfehlen.
Schneller Support, PlugIn funktioniert perfekt und ist eine sehr gute Ergänzung für viele Flows
by CRJ
31 August 2023 18:04
Herausragender Service. Hat schnell und kompetent ein Kompatibiltätsproblem behoben.
perfect plugin
by Giulio R.
27 July 2023 10:25
I initially had a problem but the Acris team is very helpful. 5 stars for them, very serious company.
Unverzichtbares Plugin für alle die Workflows automatisieren möchten
by Wolfgang Pöltl
14 June 2023 10:10
Ein absolutes Muss für alle Shopbetreiber, die ihre Workflows automatisieren möchten! Dieses Plugin erweitert den Shopware-Standard basierend auf dem FlowBuilder und bietet die Möglichkeit, zeitverzögerte "Actions" durchzuführen. Dadurch können Bestellstatus und Zahlungsstatus automatisch gesetzt werden, ebenso wie zeitlich verzögerte E-Mails verschickt werden können, wie beispielsweise Zahlungserinnerungen oder Bewertungsanfragen nach erfolgreicher Lieferung und Nicht-Retournierung der Produkte. Dieses Plugin ist praktisch unverzichtbar für jeden Shopbetreiber!
  • Extensions: 168
  • Based in: Austria
