Staging System / Developement System / Testing System (without additional costs for plugins)
Rating: 4.8
(19 reviews)
  • Easy setup: create a test environment with a few clicks
  • No extra plugin costs: plugins work without relicensing
  • DSGVO compliant, as customer data and orders are only copied on request.
  • Several test environments can be managed / set up as many test environments as you like (with profile management)
  • Easy copying or deleting of test environment (file structure and database)
Why a test environment / staging environment / test system / staging system makes sense:
  • Test updates, plugins, themes and settings without risk
  • Simple operation, reduction to the essentials
  • No additional shopware or plugin license required
  • DSGVO compliant, as customers and orders are only transferred to the test system on request,
Configuration
In the Shopware Admin area under Settings -> Plugins -> Staging-System has been added. In the first step please "add" a new staging-system.
  • Internal name: is only used for the overview if you create multiple staging / test systems.
  • Directory: into this directory (e.g. staging) the complete Shopware 6 system will be copied and can be accessed after creation in the frontend under www.Domain.com/staging or admin area www.Domain.com/staging/admin
  • Database host: if the database is located on the same server as the Shopware system's website, use the default value; if not, use the host from the database server. Default value: "localhost".
  • Database name: enter the name for the test environment database
  • Database user: enter the user for the test environment database
  • Database password: enter the password for the test environment database
  • Shop owner e-mail address: If a different shop owner e-mail address is to be used for the test system than in the live system. Otherwise leave it empty.
  • Maintenance mode: If this is activated, the test system will be put into maintenance mode after the test environment has been created.
  • Copy orders: for DSGVO reasons the orders should not be copied for test systems, but this is possible with set hacking.
  • Copy customers: for DSGVO reasons the customers should not be copied for test systems, but this is possible with set hacking.
Before the actual copying takes place, please save the configuration and then the button "Create Staging System" is active.
The creation of the staging system / test environment can take some time.
In the overview of our plugin you can see when the staging environment was created and you can easily "overwrite" or delete it with the saved data. If the staging environment is deleted, both the subdirectory and the database will be deleted.
Technical Requirements / Notes
  • Creation of an empty database required (for staging / test database)
  • Additional settings may be necessary for the hoster (e.g. for TimmeHosting the nginx configuration for Shopware 6 must be assigned to the subfolder)
  • If cron jobs are required for staging, these must be set up at the hoster.
  • If the staging environments are not created correctly, it could be due to a timeout. In this case, please increase the php.ini and timeout of PHP Scripts. max_execution_time.
  • Make sure that there is enough space on the server - everything is copied 1:1, which means that shopware and all content data is duplicated.
  • Latest update: 6 May 2025
  • Publication date: 15 June 2020
  • Version: 4.5.2
  • Category: Administration
Reviews (19)
Based on 19 reviews
4.7 Functionality
4.7 Usability
4.7 Documentation
4.8 Support
95 %
5 %
Eine klare Empfehlung!
by Anna D.
3 March 2025 14:23
Das Plugin spart viel Zeit bei der Erstellung einer Testumgebung. Das beste dabei: die Plugin-Lizenzen sind auf Staging auch sofort gültig.
Der Support ist sehr gut.
Guter Support
by Kai Voigt
28 January 2025 15:20
Lizenzierungsproblem
by Stefan Schwarz
9 December 2024 14:59
beim Test in der ACRIS-Staging Umgebung haben wir eine Erweiterung eines anderen Anbieters getestet und diese wieder gekündigt. Dies führte zu jedoch zu Server - Fehlermeldungen, so daß (nur)die Testumgebung nicht mehr erreichbar war. Der Support von ACRIS war außerordentlich schnell und hilfreich.
Insgesamt wie sich zeigt ein wichtiges und gut bedienbares Tool mit tollem Service!
4.0 Documentation
Top Support
4.5
by HorstUwe
26 November 2024 13:22
Extrem schneller Support bei einer Updatefrage. Problem wurde sofort beseitigt. App funktioniert sehr gut.
4.0 Usability
4.0 Documentation
Hammer Plugin - MEGA Support ⭐️⭐️⭐️⭐️⭐️
by Ursula_NEU R.
7 November 2024 10:42
ACRIS steht bei uns für Qualität und Zuverlässigkeit.
SuperDank an den Support und auch an den Chef Wolfgang Kern der sich eisern gegen die Servicewüste Deutschland stemmt und das sehr erfolgreich.
Das Plugin war in meinem Fall schwer zu installieren, es brauchte einen extra spezial Chronjob. Dank der mega ACRIS Unterstützung hat letztendlich alles gut geklappt.
Diesen Pluginanbieter und dieses Plugin kann ich von ganzem Herzen weiterempfehlen.
Sehr geil!
by Bastian Schröder
17 September 2024 14:33
Tool, spart viel Zeit und der Support ist Klasse!
Sehr gutes Staging Plugin
by Mikuteit
10 September 2024 09:00
Klasse App! Drei Funktionen würde ich mir noch wünschen!
1. FTP Daten für Staging. Bei uns liegt der Stage Shop auf anderen FTP Daten. Wäre klasse, wenn man die dort eingeben könnte
2. Menü Punkt zu der Staging Umgebung direkt aufrufbar
3. Stage aktualisieren. Wenn sich im Haupt Shop etwas ändert, wäre es doch klasse, wenn ich die Stage einfach per Knopfdruck wieder auf den gleichen Stand bringen könnte.
Ansonsten macht es alles was es soll! Klasse Plugin.
Sind halt noch einige Ideen...
4.0 Functionality
kleiner Fehler wurde super schnell behoben.
by Manfred Hunkel
21 June 2024 20:22
Support ist der Wahnsinn
by Christian
22 May 2024 17:14
Wir hatten einige Probleme im Shop und auch mit dem Plugin und uns wurde so schnell, unkompliziert und professionell geholfen. Wenn es davon nur mehr gäbe...
Sehr gutes Plugin mit perfektem Support
by Juri Oll - BEJOYNT
13 May 2024 12:10
  • Ø-Rating: 4.9
  • Extensions: 156
  • Based in: Austria
