Customer-specific part numbers / Customer-specific product numbers
  • Add customer specific part numbers in admin to products (and suitably due B2B customers).
  • Display customer specific item number in storefront: Product detail page, Checkout, My account (plugin configuration).
  • Customer specific item has also been integrated into search, so searching for it is possible (customer must be logged in)
  • Store customer-specific product numbers / article numbers directly with products (in the admin area).
  • After the login of the corresponding customer, the customer specific item numbers are available in the storefront
  • Display in frontend - product detail page, checkout, my account (plugin configuration) - optional.
  • Additionally selectable: display of product number + customer specific product number or only the product number of the store. (Plugin configuration)
Purpose of the plugin
In B2B, it is common for B2B customers to want to have their own part numbers displayed with products and also a search for their own part numbers (product numbers) is a frequently requested feature.
This plugin now makes it possible to add custom part numbers to products.
These customer specific product numbers (item numbers) can be displayed on the product detail page after logging in to the storefront.
In addition, the customer specific part number has also been integrated into the search, so that it is possible to search for the "original product number" and also for the customer specific part number.
Use of the plugin
After successful installation of the plugin, an additional tab is available in the products (Shopware Admin: Catalog > Products) "Customer-specific item numbers". In this tab, customer-specific article numbers can now be added - to do this, a (B2B) customer is selected and the desired customer-specific article number is added.
The customer-specific article number can then be displayed on the product detail page, in the checkout, in the My Account area (in the orders). The configuration of the display settings can be set in the plugin settings.
  • Latest update: 24 July 2025
  • Publication date: 1 June 2022
  • Version: 4.0.2
  • Category: B2B extensions
  • Ø-Rating: 4.9
  • Extensions: 156
  • Based in: Austria
