Set different product images per languages
If different product images are to be used for different languages, then this is not possible in Shopware Standard - exactly this function is provided here.
Compatible with:
6.4.0.0 - 6.6.10.4
Includes:
Why do you need that plugin
You want to use different product images for a product, depending on the selected language - then this is not possible with the Shopware standard. An image can only be displayed in all languages and thus sales channels.With this plugin you can define which product image should be displayed for each language.
Use of the plugin
After successful installation of the plugin, new functions are available for the products in the media area.When you mouseover a product image in the admin area, the familiar ... If they click on it, "Configure image/cover" appears, the following configurations are then possible:
- Use as default cover
- The image should be available in the following languages
please type in the desired language for which the image should be displayed
- After the language has been selected, the function Use this image as cover for "xxxx" will appear
- Available: English, German
- Latest update: 21 May 2025
- Publication date: 19 April 2022
- Version: 3.0.1
- Category: Language & Internationalisation
Bronze Partner -
- Ø-Rating: 4.9
- Partner since: 2015
- Extensions: 156
- Based in: Austria
- Speaks: German, English
- Response time: Very quickly
