Filter Pro - Filter as slider, category filter in search, number of products
Rating: 4.9
Average rating of 4.86 out of 5 stars
(7 reviews)
  • Individually configurable filters
  • Property filters with range selection or sliders for numerical values
  • Category filters can be activated directly next to the shop search
  • Flexible filter display – via the ‘More filters’ button or in the off-canvas
  • Filters can be shown or hidden and their order can be adjusted
  • Property filters with range selection or sliders for numerical values such as size, length or price
  • ‘Show products’ and ‘Remove filters’ buttons can be activated in the off-canvas
  • Filter display can be customised individually for desktop, tablet and mobile devices
  • Number of products and hits per filter option can be displayed
  • Readable filter parameters can be activated in the URL
  • Shopware main filter can be customised individually
Purpose of the plugin
The plugin expands Shopware's standard filter functions with a wide range of display and configuration options. This allows the entire filter logic to be individually adapted to the design and requirements of the shop.
Individual filter configuration
Filters can be flexibly activated, positioned and controlled in terms of their visibility. In addition to custom property filters, which can be configured as range sliders or min/max input fields for numerical values such as size, length or price, existing main filters such as price, manufacturer or ratings can also be customised. This allows you to specify exactly which filters are displayed, in which order they appear and whether they are displayed in the main area or under ‘More filters’.
Flexible display options
The ‘More filters’ area can be displayed either as a drop-down menu or in the off-canvas. Separate settings are available for desktop, tablet and mobile devices to optimally adapt the filter display to the respective end device. In addition, various display options can be individually configured, such as the display of active filters, the number of hits or the display of colours and texts. In addition, a category filter can be activated directly in the shop search so that customers can narrow their search to specific categories.
SEO and performance optimisation
Filter parameters can be output as readable, SEO-friendly URLs to improve search engine visibility. In addition, the plugin optimises the loading of property filters on the search page, reducing loading times for extensive product catalogues. Filters without results are automatically deactivated, maintaining clarity for customers.
  • Latest update: 20 May 2026
  • Publication date: 19 March 2021
  • Version: 9.9.3
  • Category: Search & Filter
Reviews (7)
Based on 7 reviews
4.7 Documentation
4.7 Support
86 %
14 %
Super aber mega teuer
4.0
by Manu
4 December 2024 10:51
Macht was es soll, ist aber halt mega teuer.
3.0 Documentation
3.0 Support
Super Plugin
by Anke
13 September 2023 15:24
Das Plugin stellt Funktionen zur Verfügung die im Standard leider nicht zur Verfügung stehen. Es ist einfach zu konfigurieren und der Support reagiert super schnell. Hatten einen Verbesserungsvorschlag und nach einem Tag stand schon eine neue Version zum Download zur Verfügung. Danke!
Freundlicher Support, schnelle Reaktion
by Atilla Boz
10 August 2022 23:54
Ich hab zuerst die Einstellung nicht gefunden - der Support hat zügig geantwortet und die Welt war wieder in Ordnung. :) Praktisches Plugin zur Sidebar-Optimierung.
Super Support
by A. Harbott
1 July 2022 14:26
Fehler in Kombination mit einem anderen Plugin wurde zügig gefunden und behoben. Vielen Dank für den tollen und freundlichen Support.
Funktioniert perfekt und sehr guter Support
by Daniel Haug
7 April 2022 09:37
Ein anderes Plugin wurde nicht mehr angezeigt nach der Installation. Innerhalb kürzerster Zeit gab es ein Update. Nun funktioniert alles super.
Super Plugin, schneller Support
by Michael Wetzel
18 February 2022 13:50
Das Plugin erfüllt für unseren Zweck voll und ganz die Funktionalität mit der Filterdarstellung. Sehr rasche Antwort vom Support.
Sehr schneller Support | Tolles Plugin
by M. W.
11 February 2022 10:51
Anfangs gab es Schwierigkeiten, wurde durch den Support aber rasant gelöst. Sehr freundlicher Support. Wir sind zufrieden.
  • Extensions: 191
  • Certifications: 7
  • Based in: Austria
