Product Info Text
Using the plugin
The entry "Product Info Texts" is added in the Shopware Admin area, in the Catalogues menu.In addition, under: Settings -> Plugins -> Product Info Texts an entry for content maintenance is created.
First please create a dynamic product group
In the area Catalogues -> dynamic product groups, please create a corresponding rule for which the product info text(s) should be displayed.Then create a product info text
In the area Catalogs -> Product info texts -> AddConfiguration / setting options
Internal name: is only used internally, for the overview page "Product Info Texts
Internal description: only used internally, for the overview page "Product Info Texts
Info Text: here you enter the text that will be displayed in the frontend on the product detail page and in the shopping cart. Please insert images with HTML code.
Active: active or not active
Dynamic product groups: The info text is displayed for all products that are determined by the dynamic product group(s). Several dynamic product groups are possible.
Sales channels: It is possible to display the texts in one or more sales channels.
Display of the product info on the product detail page: Selection from various display position options
Display in the shopping basket / ordering process: Selection from various display position options
Possible application scenarios (a corresponding dynamic product rule must be created)
- Products are not available in a country of delivery (possibly with a corresponding picture reference)
- Products are bulky goods (possibly with bulky goods logo)
- Products are in action (possibly action logo)
- Products require a legal notice (only available from 18 years, approval by xyz required, ...)
- Products can be delivered immediately (rule stock level > 0)
- Display of maintenance information for specific products
Tips & Tricks & FAQs
How can I insert an image / logo?
The Shopware Standard Editor does not provide an appropriate symbol for inserting an image - but with a little trick it is still possible:
In the upper right corner of the editor is a small symbol: > If you click on this symbol, the editor switches to HTML mode.
If you now insert and save the HTML code for an image, the image will be used.
Example:
Click again on the symbol > and you can see the picture in the preview.
What if multiple dynamic product rules apply to a product - can I display multiple product info for one product?
Yes, if you create different dynamic product rules and assign the appropriate rule in the "Product Info Text" administration, then you can also display multiple product info texts. You can also easily control where the individual product info texts are displayed by using different placements.
If several Product Info Texts are displayed at the same placement, then currently a random order is used - in a future version it will be possible to control priorities.
Is it possible to use more than one dynamic product rule for a "Product Info Text"?
yes, this is possible.
Is time control possible?
unfortunately not yet, this is planned in a future version - maybe you can adjust the dynamic product rules.
Is it possible to influence the placement of the info texts (except the 7 currently possible placements)?
if you give us some ideas where a placement makes sense, we will check a corresponding implementation in one of our next versions of the plugin.
How can I display the info texts in the order confirmation e-mail (or other documents like invoice, delivery note etc.)?
Currently this has not been implemented, maybe we will provide a HTML code for integration soon.
- Available: English, German
- Latest update: 19 March 2026
- Publication date: 22 May 2020
- Version: 6.1.1
- Category: Detail Page
Reviews (2)
Das Plugin und der Support sind ausgezeichnet.
Zuverlässig und empfehlenswert
Bronze Partner -
- Ø-Rating: 5
- Partner since: 2015
- Extensions: 188
- Certifications: Certifications
- Based in: Austria
- Speaks: German, English
- Response time: Very quickly
