Summarize product descriptions with AI
  • Create AI product summaries
  • Automatic background generation for all products
  • Flexible placement on the product detail page
  • Summaries in different languages and lengths
  • AI-generated summaries of a long product description.
  • Freely selectable position of the summary in the storefront: top, bottom, left, right, or in place of the original description.
  • Optional marking of the summary with an icon.
  • Multilingual support.
Purpose of the plugin
In the standard version of Shopware, there is no built-in way to automatically convert lengthy and often confusing product descriptions into concise, easy-to-understand summaries.
We have therefore developed a plugin that uses artificial intelligence to create concise and engaging product summaries and displays them flexibly within the shop.
AI-based product summaries
The plugin automatically generates short, easy-to-understand summaries from existing, often very long product descriptions. This allows customers to see the most important information at a glance, without having to read through lengthy texts. The length and level of detail of the summaries can be customised.
Flexible generation
There are two flexible options available for generating summaries. On the one hand, summaries can be generated for specific products at the touch of a button. On the other hand, summaries can be generated automatically for all products in the background, thereby significantly reducing the maintenance workload. The product summaries can also be generated in various languages, making them ideal for international shops.
Flexible placement on the storefront
The generated summaries can be positioned flexibly on the product detail page. Whether above the description, below it, to the side, or as a complete replacement for the original description.
Important note regarding use
An active OpenAI account is required to use the plugin. Using the AI services may incur additional costs. We therefore recommend leaving automatic background generation disabled initially (default setting) to better manage usage and the associated costs.
  • Available: English, German, Dutch, Italian, French, Bosnian, Czech, Danish, Finnish, Norwegian, Polish, Portuguese, Spanish, Swedish, Turkish
  • Latest update: 13 March 2026
  • Publication date: 30 March 2026
  • Version: 1.0.13
  • Category: AI Tools
  • Extensions: 189
  • Certifications: 7
  • Based in: Austria
