Call products with product number in URL instead of UUID number
(1 reviews)
  • Product pages can be easily linked using the product number
  • Call product detail page with the product number (without knowledge of the exact SEO URL).
  • Automatic redirection of the technical product URL to the SEO URL via 301 redirect
Initial situation
In Shopware Standard, a product can only be called up either with the complete path or with the Technical URL - but not with the product number. In addition, there is the problem that a Technical URL exists in the background for each product and these may be indexed by bots.
Function of the plugin
This plugin makes it possible to 1.) to call products only with the product number (without knowledge of the exact path)
and additionally 2.) redirect the Technical Product URL with a 301 redirect automatically to the correct Product URL.
1.) Calling a product with the product number
In order to call a product only with the product number, it can be done in one of the following format:
  • https://DOMAIN.de/PRODUCT-NUMBER-12345 (since plugin version 3.1.0)
  • https://DOMAIN.de/detail/PRODUCT-NUMBER-12345
This makes sense, for example, when linking to the store from external pages or if the call center should quickly get directly to the product detail page.
Example:
https://www.DOMAIN.de/detail/PRODUCT-NUMBER-12345 redirected to the nice SEO URL
https://www.DOMAIN.de/Fantastic-Copper-Liquid-Qleen/PRODUCT-NUMBER-12345
2.) Automatic 301 redirect when calling the technical product URL
Each product in Shopware can be called via 2 URLs - Example:
  • Example 1: via search and navigation respectively:
  • Example 2: via the UUID of the product (= Technical URL)
    https://www.DOMAIN.de/detail/a08dbdd2dc7047bcb7497699e4c762e5
The ACRIS Plugin redirects immediately from the Technical URL to the nicer URL with the product number in the URL (301 Redirect).
This ensures that the users and especially the bots are immediately redirected to the correct URL and do not index the Technical URL.
  • Latest update: 1 June 2026
  • Publication date: 5 May 2022
  • Version: 4.0.0
  • Category: B2B extensions
Reviews (1)
Based on 1 reviews
Super Plugin
by Tobias
24 August 2023 13:39
Hatten ein Problem, das innerhalb eines Tages vom Support behoben wurde Klasse!
  • Extensions: 191
  • Certifications: 7
  • Based in: Austria
