Assignment of Cross-Sellings with Product Tags - Bulk Edit via Tags
Tag-based Cross-Selling – Flexible and Automated
Increase your sales with Tag-Based Cross-Selling! This plugin extends Shopware 6 with a powerful cross-selling function linked directly to your product tags.
Effortlessly create relevant product recommendations that automatically appear on product detail pages as soon as a product has the corresponding tag. The configuration is seamlessly integrated into the Shopware Administration.
The most important functions at a glance
- Direct Tag Integration: Manage cross-sellings directly in the tag settings (Settings > System > Tags).
- Two Assignment Types: Choose between manual product assignment (Product list) or dynamic Product streams.
- Flexible Positioning: Place the tag cross-selling above the standard cross-selling, below it, or as its own tab.
- Sorting & Limit (for Streams): Control the display for product streams with sorting options (Price, Name, Release Date) and a product limit.
- Easy Configuration: Title, position, and active status can be set individually for each tag.
How it works: Seamless Admin Integration
After installation, you will find a new Cross-Selling tab in the Administration under Settings > System > Tags when editing any tag.
Here you can configure all settings for the cross-selling linked to this specific tag.
Two Modes
1. Dynamic via Product Stream
Select Product stream as the type and assign one of your predefined product streams. The plugin loads the products automatically and keeps them up-to-date via the stream. You can set the sorting (e.g., "Price descending") and the maximum number of products to display ("Limit").
2. Manual via Product List
Select Product list as the type to add products manually via search. You have full control and can adjust the order of the products using position numbers. The assigned products are displayed clearly in a table.
Display in the Storefront
Via the plugin configuration (Extensions > My Extensions > Tag Cross-Selling > Configuration), you can globally define where the tag cross-sellings should appear on the product detail page:
- Above cross-selling: Displays the tag sliders before the standard Shopware cross-sellings.
- Below cross-selling: Displays the tag sliders after the standard Shopware cross-sellings.
- As separate tab: Integrates the tag cross-sellings as their own tabs into the existing cross-selling tab menu.
If products have multiple tags with configured cross-selling, they are displayed sequentially (sorted by the position set in the tag).
- Available: English, German
- Publication date: 29 January 2026
- Version: 2.1.0
- Category: Conversion Optimization
Reviews (1)
Cross-Selling mit Mehrfachänderung nun möglich
Web Labels Webdesign GmbH
Technology Partner Silver -
Bronze Partner -
- Ø-Rating: 4.6
- Partner since: 2016
- Extensions: 57
- Certifications: 2
- Based in: Germany
- Speaks: German, English
- Response time: Very quickly
