Web Labels Webdesign GmbH
Product Advisor & Product Finder
(2 reviews)
  • Smart product recommendations through weighted questions
  • Define questions by properties, manufacturers, or price
  • Single or multiple answers per question supported
  • Flexible required fields or skippable questions
  • Results sorted by relevance with manufacturer prioritization
  • Create unlimited product advisors directly in the admin
  • Pre-filter products using Dynamic Product Groups
  • Individual descriptions and images per question and answer
  • Multiple or single selection configurable per question
  • Question weighting influences result order
  • Top product recommendation at 100% match
  • Configurable number of displayed results
  • Easy integration into any Shopping Experience via CMS block
  • Live result updates after each answer
  • Manufacturer prioritization for preferred brands
  • Conditional question logic: Skip questions based on answers
Intelligent Product Advisor for Shopware 6
Looking for a product advisor that weighs answers intelligently instead of just matching "yes" or "no"? Our smart product advisor guides your customers to the perfect product in just a few steps – boosting your conversion rate.
The Problem: Standard Filters Aren't Enough
Imagine: A customer wants a red mountain bike with 27-speed gears and oil-pressure suspension. You have the perfect bike – but only in black. In a physical store, you'd still recommend it because it meets all technical requirements.
That's exactly what our product advisor does: It weighs answers intelligently and recommends products by relevance – not just exact matches.
Key Features
  • Smart Weighting: Each question gets an individual weight. Technical requirements can outweigh color preferences.
  • Dynamic Product Groups: Pre-filter which products enter the advisor (e.g., in-stock only, specific manufacturers, price range).
  • Live Updates: Customers see matching products instantly after each answer.
  • Manufacturer Prioritization: Prefer certain brands in results.
  • Conditional Question Logic: Skip questions automatically when previous answers make them irrelevant.
  • Multi-Language Support: Translate questions and answers directly in the advisor – no separate advisor per language needed.
  • Variant Support: The search algorithm also considers variant options.
Easy Integration
Create unlimited product advisors directly in the admin under "Catalogues → Product Advisor". Add them to any Shopping Experience via CMS block. New products are included automatically – no manual updates required.
Documentation
Find comprehensive documentation with step-by-step guides, best practices, and configuration examples at docs.web-labels.de.
  • Available: English, German, Dutch, Italian, French, Czech, Danish, Polish, Spanish, Swedish
  • Publication date: 21 July 2021
  • Version: 7.3.0
  • Category: Search & Filter
Reviews (2)
Based on 2 reviews
4.5 Usability
Top Plugin - Kunden nutzen den Berater bei uns im Shop regelmäßig
by John
17 June 2024 11:42
Ein Abzug nur in der Funktion da es aktuell noch kein Range-Slider gibt. Soll aber in Entwicklung sein und bald kommen. Sonst leicht zu bedienen und Funktioniert super nach Gewichtung der Eigenschaften zu sortieren. So kommen am Ende die wirklich guten Produkte beim Kunden an.
4.0 Usability
Benutzerfreundlich - leicht zu bedienen
by Stefan Elskamp
30 November 2022 14:49
Macht was es soll und funktioniert super.
    Technology Partner Silver
  • Ø-Rating: 4.6
  • Partner since: 2016
  • Extensions: 57
  • Certifications: 2
