EU Cookie Policy Pro + Auto Cookie Detection (SW6) + Load scripts only after approval + Google Consent Mode V2 support
In-App Purchases
Subscriptions
Supports Google Consent Mode V2 (see below for documentation and demo container)
Recommended by the IT-Recht Kanzlei Munich: https://www.it-recht-kanzlei.de/rabatt-mandanten-eucookierichtliniepro-shopware.html
Improves the EU Cookie Policy compliant use of your webshop.
Since
Shopware 6 can not prevent cookies from
external scripts (eg Google Analytics) and thus tracking is also
possible without accepting, this plugin is nevertheless urgently needed.
- Non-functional cookies of the shop domain are only allowed in the shop as soon as the user accepts the cookie hint.
- The cookie hint allows the user to activate / deactivate single cookies or whole cookie groups individually.
- Cookies unknown to the plugin will be recognized automatically. These can then be titled by the shop owner and activated for selection in the store. Publicly known cookies (such as Google Analytics, Facebook Pixel, Amazon Pay, Livezilla, Cloudflare, Emarsys and many more) are automatically added to the cookie hint.
- Cookies are automatically assigned to the recognized sales channel and only displayed there in the notice.
- In the plugin settings you can switch between two layout options (Classic cookie note and modal window - since version 1.1.0).
- Shop customers can adjust cookie settings after accepting (to set up the feature, see the installation instructions).
- Buttons "Accept only functional cookies" and "Accept all cookies" can be to the note by plugin configuration if required.
- from version 5.0: Scripts can now be loaded after approval - to do this, create a new "cookie" and fill in the corresponding fields.
- New from version 5.3: Google Consent Mode V2 support
Technical functioning
The plugin recognizes all cookies set via HTTP or via Javascript from an internal (e.g., Shopware CSRF token) or externally loaded script (e.g., Google Analytics). All cookies that are not set for the shop domain and set by an external loaded resource (eg iFrame integration) for an external domain (eg www.paypal.com) can not be recognized by the plugin due to the same origin policy (browser security guidline) and can not be prevented. As an example, this concerns payment bindings loaded via iFrames (e.g., Paypal Express Shopware plugin).
Please note
The Plugin manufacturer assumes no liability for the complete DSGVO conformity and no claim to legal certainty can be asserted. In particular, it should be noted that each case is to be considered separately and does not replace individual legal advice.
Information about implementing Google Tag Manager
https://www.acris.at/media/77/32/3c/1709126654/SW6_Doku_Cookie-Richtlinie-Pro_Tag-Manager_V61_EN.pdf
Container template for the import into the Google Tag Manager (please unpack ZIP archive)
https://www.acris.at/media/80/03/a3/1773766038/GTM_Container_Vorlage_bitte_entpacken_v9.zip
In-app purchase: Cookie Statistics
The optional in-app purchase ‘Cookie Statistics’ is available within the plugin for analysing cookie consents.
The Cookie Statistics feature allows shop owners to track, via the admin panel, how visitors interact with the cookie notice. The selected consent types are recorded statistically and clearly displayed in the backend.
Features of the in-app purchase
- Analysis of cookie consent in the admin panel
- Displays whether visitors have accepted all cookies, no cookies, only functional cookies, or selected cookies
- Customisable analysis period for flexible reporting
- Automatic deletion of older statistics entries after a configurable period
Scripte, Bilder, iFrames und Links einbinden (im HTML Code) (wenn es nicht möglich ist, Scripte wie vorgesehen im Cookie Manager einzubinden)
- Zuerst ein neues Cookie anlegen und dann kann die CookieID entsprechend verwendet werden:
LEIDER IST DER BEISPIELCODE HIER NICHT SICHTBAR - bei Bedarf kann der Beispielcode via Supportanfrage bei uns angefragt werden !Image
Vorher:
Nachher:
Iframe
Vorher:
Nachher:
Skript direkte Einbindung
Vorher:
Nachher:
Skript Einbindung über src
Vorher:
Nachher:
Link
Vorher:
Nachher:
Für "img" oder "iframe" gibt es auch die Möglichkeit einen alternativen Text anzuzeigen.- Es muss ein Element mit der Klasse "acris-cookie-info", direkt danach eingefügt werden. Bespiel.:
Externe Inhalte werden nach der Bestätigung des Datenschutzhinweises geladen.
Oder ein Info Text - Beispiel.:
Externe Inhalte werden nach der Bestätigung des Datenschutzhinweises geladen.Mit dem ACRIS CMS Modul und dem HTML-Element lässt sich dann auch noch schön Twig Code verwenden. Beispiel:
{% sw_include '@Storefront/storefront/utilities/alert.html.twig' with { type: "info", content: "Externe Inhalte werden nach der Bestätigung des Datenschutzhinweises geladen." } %}
- Integrating scripts via other plugins / apps
1. A cookie must first be created in the admin (Settings > Extensions > EU Cookie Policy Pro > Cookies). The cookie ID can be: "my_cookie". The cookie must have a default value entered. In our example, this is the value 1.
2. The following script can then be inserted in the other extension:
import CookieStorage from 'src/helper/storage/cookie-storage.helper';
init();
function init() {
const cookie = CookieStorage.getItem('my_cookie');
if(cookie === '1') {
loadMyScript();
function loadMyScript() {
const script = document.createElement('script');
script.async = true;
script.src = 'https://www.my-script.com/script.js';
document.body.appendChild(script);
Complementary Extensions for Tracking & Consent
The following plugin extend tracking and consent functionality in Shopware and can be used in combination.
Google Tag Manager – GA4, Google Ads & Server-Side Tracking
Enables centralized integration and management of tracking services and supports modern tracking methods.
- Available: English, German
- Latest update: 16 June 2026
- Publication date: 10 February 2020
- Version: 10.0.11
- Category: Special features
Reviews (38)
Super PlugIn
Hier macht man nichts falsch.
Great Service!
Herzlichen Dank
Wie immer ...
Sie tun, was sie versprechen, funktionieren wie dokumentiert und der ausnahmslos freundliche Support ist gerne hilfsbereit und offen für konstruktive Änderungen.
Top service
Super Cookie Plugin mit klasse Support! Absolute Empfehlung!
Klasse Plugin mit super Support
Gutes Plugin und schnelle Reaktionszeit beim Support
Super Plugin mit noch besserem Support
Alles wunderbar :)
Bronze Partner -
- Ø-Rating: 5
- Partner since: 2015
- Extensions: 196
- Certifications: 7
- Based in: Austria
- Speaks: German, English
- Response time: Very quickly
